Tool Talk Discussion Forum
Best rubber dip for tool handles?
Ebbsspeed
11-25-2007 10:51:02
A lot of my tools are "used" enough to where the rubber coating on the handles is long gone. I'd like to recoat them, would like any recommendations on what products some of you may have used, how well it holds up, etc. Give me the good, as well as the bad so I know what to stay away from.
335LP
11-27-2007 09:21:00
 Re: Best rubber dip for tool handles? in reply to Ebbsspeed, 11-25-2007 10:51:02
Check with a industrial tool supplier like Grainger and others and they have some vinyl or insulated replacement grips you heat in hot water or with a heat gun and slip on. They make some for the Kline linesman pliers. A lot of that cheap tool dip is just that not worth buying and solvents will disolve it making it soft and fall off first time anything gets on it.
Roy Suomi
11-25-2007 16:53:43
I use Heat Shrink tubing used for insulating electrical connections..The kind with the mastic inside the tube is best..Don't hurt to use several layers and pinch the plier handle ends to conceal the ends..
Dusty MI
11-25-2007 16:08:08
I've put a little CO2,from my TIG welder, in a can of tool dip after opening, it seems to keep a little longer.
Tim Casbolt
11-25-2007 12:28:01
Link
Wardner
11-25-2007 11:35:28
Home Depot sells the stuff. It is formulated and labeled for tools. I use it for insulating electrical connections. Once the lid is popped, its shelf life deteriorates fast even with the substitute plastic lid which they provide.
shannon from ohio
11-25-2007 16:04:11
 Re: Best rubber dip for tool handles? in reply to Wardner, 11-25-2007 11:35:28
Best way to preserve the shelf life of the plastidip Indefinitley upon opening is to put aluminum foil over can opening,put plastic lid on and turn can "Upside down"
azharry
11-25-2007 11:32:29
U Coat it or U dip it are probably the most common plastic dips. However, nothing I have found equals the original rubber/vinyl grips on tools. The dip it products go on cold and you have to use several coats for thickness to be worthwhile. I have also experimented with heatshrink tubing. The heatshrink tubing with the glue inside works great but, it's still not as good as original. Whatever you use, make sure the tool handles are super clean before coating them. Good luck,
Ken Crisman
11-25-2007 11:30:46
Hi , I never bought any dip, but I could've sworn I saw it in Eastwood catalog once . Go to their website & ask them . What I have used, as a former electrician (before disability hit)was shrink tubing . I've even used 2 pieces on each handle to be sure I was protected . I've even used it on the shafts of screw drivers that I used near hot wiring .It always worked for me & has stayed for all the years I've had the tools .HTH ! God bles, Ken
135 Fan
11-25-2007 11:29:59
There is stuff made just for that that comes in different colours but I can't remember the name of it. Dave
