Tool Talk Discussion Forum
Coats 20-20 tire changer
zuma
11-24-2007 04:08:55
Looking for instruction manuel, also lube bottle for 20-20 Coats Thanks
JoeK(WI)
11-25-2007 04:46:57
 Some don't read good :) in reply to zuma, 11-24-2007 04:08:55
Go to the source :)
Slowpoke
11-24-2007 22:14:56
 Re: Coats 20-20 tire changer in reply to zuma, 11-24-2007 04:08:55
I use a shampoo squirt bottle held in a tin can mounted to the side of my 10-10 changer. I put the lube on the tire and rim then use a clean rag to remove the dirt. I also us steel wool to clean rims, then squirt more lube on, spread it with my fingers, and mount tire. Or go to the dollar store and see what you can find there.
135 Fan
11-24-2007 10:22:13
Murphy's makes a tire mounting soap. I saw a guy use it to mount huge skidder tires by hand. He grabbed hand fulls of it to slop all over the tire. It's the same Murphy's that makes oil soap. Dave
bradk
11-25-2007 00:26:02
 Re: Coats 20-20 tire changer in reply to 135 Fan, 11-24-2007 10:22:13
I second Murphy's oil soap for lube.Cheap stuff for effectiveness.Ebay for man.~brad
Jim in Ma.
11-24-2007 08:36:00
I get my tire lube from Napa
GF-MN
11-24-2007 06:49:35
BIG 10-4 ON THE BOWES LUBE. BEEN USING IT FOR THE PAST 25 YEARS ON TRUCK TIRES PLUS MY FARM TIRES-IT,S THE BEST IF YOU CAN GET IT. WE HAVE A LOCAL BOWES DEALER. I USE A 50/50 MIX.
hd6gtom
11-24-2007 06:21:04
Go to you'r local tire shop and ask them to sell you a gallon of the tire lube they use. In the 20+ years I was in the tire business, we try'd all kinds of soaps. NONE of them are as slick as comercial tire lube. My favorite was Bowes Big Blue undiluted. You may have a place near you where they sell commerical tire supplies.
Chris(WA)
11-24-2007 04:35:05
You can get the bottles on Ebay. Thats where I got mine for about $10. What is the best lube to Use? I used soapy water yesterday on a couple tires with mediocre success.
