The dominant destructive force in an earthquake is horizontal sliding. You can visualize how best to strengthen the house by imagining a giant grabbing hold of the base of the foundation and shaking it back and forth. This also helps you to understand the probability of damage -- tall houses are worse than short houses, heavy houses (as with brick veneer walls) are worse than light houses. The standard detail for modern construction is to bolt the mudsill to the foundation, and then secure the floor joists to the mudsill with something like a Simpson A35. A rim joist or band joist is secured to the floor joists and mudsill, and the wall sheathing and its nailing ties the rim joist, wall studs, floor joists, and mudsill into a single unit (this latter detail, together with the weight of the house, and the mudsill bolts is usually considered sufficient to resist vertical acceleration). Getting back to horizontal acceleration, the bolting and A35s tie the floor diaphragm to the foundation walls, creating a shear wall system for the foundation (more important for a basement with its tall foundation walls than a crawl space). They also act to resist having the house slide sideways off the foundation along the axis of the joists. If you alternate the A35s from one side of the joist to the other as you proceed down the row of joists, then you also add strength to prevent the house from sliding sideways perpendicular to the joists. (This is for extra credit, the rim joists and wall sheathing already provide a lot of resistance to sliding in this direction). Retrofitting a house could be accomplished with an angle drill (for installing foundation bolts) and a palm nailer (for installing the A35s). You can use expansion anchors or epoxied anchors for the sill bolts. I am dubious of using angle irons bolted to the joists and foundation walls to resist horizontal sliding. The angle irons will tend to twist as the house moves sideways, tending to "work" the bolt holes in the joists and enlarge the holes. One or both of the wall bolts will be loaded in withdrawal as the house moves back and forth. This is the weakest direction for bolts retrofitted into concrete -- they are much stronger when loaded in shear perpendicular to the bolt axis. The angle iron idea seems OK for holding the house DOWN, but not so good for holding it from sliding sideways. Building departments in California offer a number of "standard details" for seismic retrofits, and you could pick one of those that is the most workable for your specific house. Washington and Oregon are not so enlightened, perhaps because the Northwest's subduction zone earthquakes are more rare (though no less severe) than California's active fault zones. You might ask around and find a real structural engineer to look at your house and draw up a detail for you. Considering how much of your time you are going to invest in this project, a few hundred dollars is not that much money to invest, and in similar situations in the past I've found the engineering to be less expensive than I'd feared.
