Tool Talk Discussion Forum
Water heater pressure relief discharge tube
Stan in Oly, WA
11-23-2007 17:03:15
My water heater P/R valve vents through 3/4" rigid copper that drops down into the crawlspace and runs about 50' to the outside. I'm upgrading the supply plumbing, and I could put that copper to better use. Could I have the discharge tube just go straight down into the crawlspace and stop? I've never had a water heater that blew off pressure even though I've owned dozens and was responsible for hundreds for a few years. This makes me feel that the odds are in my favor.
On the other hand, I'd prefer to make more of an effort now while I still can, rather than have a nasty situation in ten years when I probably won't be able to deal with it myself. The hourly rate for unskilled labor in 2017 will undoubtedly be $500, (the same as the cost of a restaurant meal or a tank of gas.) Can I do the venting through CPVC, if I decide to reroute it to shorten the run?
Thanks, Stan
IH2444
11-24-2007 09:34:05
 Re: Water heater pressure relief discharge tube in reply to Stan in Oly, WA, 11-23-2007 17:03:15
I ran mine outside thru CPVC. It's temp rating is about the same as the temp/pressure valve is supposed to pop open.
Gary from Muleshoe
11-24-2007 06:09:18
One advantage to having it run outside is you will notice if the valve begins to leak, which they often do. If you end in a crawl space a leaky valve could cause more harm than it is worth.
lucas boy
11-24-2007 04:27:53
whatever you do, i think youd be better off running it to outside, wouldnt hurt being ended in crawl space, unless it started dumping water there.
WantACaseLASomeday
11-23-2007 18:34:28
 Re: Water heater pressure relief discharge tube in reply to Wardner, 11-23-2007 17:03:15
The code here (Wichita KS) allows some grade of PVC because there is no pressure in it since it has one end open. Mine ends just above a floor drain. Before you just put it into the crawl space think about the mess you will have down there if it ever does blow. Wouldn't take much more work to run it out the same way the current pipe goes. It may not meet code if it doesn't run outside or at least to a drain.
msb
11-23-2007 17:07:49
Check your local code. That is the only reliable source of information for your situation.Here it only needs to be 6 inches off the floor.
