Tool Talk Discussion Forum
Wire Welding Question
wsmm66
11-23-2007 16:13:36
I have an inexpensive wire welder (flux only). I also happen to have a spool of non-flux wire. What would be the results of using this spool of wire, without the shielding gas. I've always been curious,as with Ox-acetylne welding you don't use a shielding gas (to my knowledge) yet it works just fine. My welding is just confined to things around the house, and I'm no where near a good weldor.
Thanks,
Bill
Don-Wi
11-23-2007 23:20:12
 Re: Wire Welding Question in reply to wsmm66, 11-23-2007 16:13:36
Won't work 1 bit. It'll look worse than chicken sheet and hold worse than bubble gum.
For O/A welding, the flame basically is the sheilding gas. The flame is burning the oxygen out so there is none there to mess up the weld.
You can try if you want to, but I promise it won't be pretty. Probably burn up a few tips trying too.
Donovan from Wisconsin
retired wrench
11-23-2007 18:38:04
I agree with Stan it won't work.At least you know the spelling between the machine and the operator.
Stan in Oly, WA
11-23-2007 16:33:06
Hi Bill,
Using bare wire w/o shielding gas will result in weld beads with porosity which makes the weld weak. They may also be quite ugly.
In comparing this situation to O/A welding, your reasoning is good but your assumption is mistaken. The O/A flame does, in fact, provide a shielding gas. I can't remember whether it is CO or CO2, or something else entirely, but it's there.
All the best, Stan
guido
11-30-2007 09:14:36
 Re: Wire Welding Question in reply to Stan in Oly, WA, 11-23-2007 16:33:06
Hey Stan
I agrere with you about the quality of the weld without the shilding it with the core material.
Early it the welding industry, that was the one ways to weld using dc current and a bunch of batteries in series, and a bare electrode, that must have been fun!.
Guido.
Joe(TX)
11-25-2007 15:01:02
Stan
welding generates gas, but it is not a sheilding gas. It is ozone.
T_Bone
11-24-2007 13:31:33
Hi Bill,
If I had not received a "free" 1928 Lincoln refference text from a Ytmag user Dad's library, I too would have responded as Stan's excellent advice indicated.
BUT, them boys in the 20's had a huge set of ka-honies as per the book "they used to certifiy welds while using BEAR electodes" while using the resistance welding process without any shielding aids.
Wow, Now I always thought I was a good weldor in the upper classmen but I really don't think I could do that. I've never tired it but it doesn't sound promising. And I thought using 1/8" electrodes at 150amps was hot puddle welding!!! I would think 200amps might be a common amp demand while using 1/8" bare electrodes.
I'm sure that the bare electrodes of the 20's contained a different electorde metal mix than today's electrodes.
Stan as too the by-products of combustion of carbon based fuels, there's Co2, CO, nitrous oxide, sulfur dixoide and other trace elements of a typical 14/1 oxygen/carbon gas mix. Most carbon fuels are considered stoichiometic at a 14/1 ratio. Of course achiving a 100% stoichiometic burn is not possible.
T_Bone
