Tool Talk Discussion Forum
Wireing help
Help1
11-23-2007 15:52:20
third party image
third party image
How do I wire this 220v wall heater?
TractormanNC
11-25-2007 16:30:18
 Re: Wireing help in reply to Help1, 11-23-2007 15:52:20
If using standard romex (black,white,bare or green) the white wire should be painted or taped with black to identify it as an UNGROUNDED conductor. code requires this I think.
Stan in Oly, WA
11-23-2007 16:24:06
If the heater has an internal thermostat as the pictures seem to indicate, then you wire one conductor to the heater's red wire, one conductor to its black wire, and the bare ground wire to the heater's bare ground wire, or its green ground wire, or its green ground screw.
The wire that is the power source should be 12-2 w/ground or 10-2 w/ground. The black wire and the white wire each carry 110V. If they are connecting to a black wire and a red wire at the heater, I don't think it makes a difference which color connects to which other color---only that each heater wire connects to only one source wire.
Hope that helps, Stan
Thanks
11-24-2007 05:58:20
 Re: Wireing help in reply to Stan in Oly, WA, 11-23-2007 16:24:06
Thanks Stan, your a big help, I thought it was set up that way, Thanks again.
banjo
11-23-2007 22:43:34
assuming it is on a double pole breaker at the panel.
Stan in Oly, WA
11-24-2007 00:42:59
 Re: Wireing help in reply to banjo, 11-23-2007 22:43:34
You're right, of course. The trouble with a question like this is that it's so broad that you can only guess where to jump in. Too basic and you risk insulting someone who's got some wiring experience, maybe only hasn't installed a 220v heater. But if you start too far along in the process you might blow right past the thing being asked. Everything is kids' stuff for someone, absolute gibberish to someone else.
All the best, Stan
T_Bone
11-24-2007 12:26:04
 Re: Wireing help in reply to Stan in Oly, WA, 11-24-2007 00:42:59
Hi Stan,
I've given alot of thought as too how much information to answer with. I came to the conclusion that even if the request is basic in nature, there's other newbie's just learning so they would require additonal info incase they searched the archives first before posting a new thread.
I can only remember a couple times that someone really didn't like my basic to advance answer writing style. What does that mean? You got me... LMAO
The only thing I dislike about using controls to break only one side of a 240v circuit connection is you still have 120v to ground live at all times when the unit is shut off thus the circuit will supply 120v to the fan motor, pump motor, transformers etc, causing excessive componet wear because of the heat generated thru the always on 120v conection. You would generate heat as the 240v componet would act as resistor in the 120v mode.
T_Bone
