Tool Talk Discussion Forum
another electrical question (florescent light)
ldj
11-23-2007 15:41:29
I have a fixture with 2 96" florescent lights in it. One quit working. I can take it out and the other won't work. I changed them around and the one in that position still won't work. So, both bulbs work on that one side. Since the bulbs are old, I bought new bulbs and it is the same way. I cleaned the contacts where the bulbs fit and didn't help. Any suggestions?
L.D.
Bud in WV
11-24-2007 04:28:51
 Re: another electrical question (florescent light) in reply to ldj, 11-23-2007 15:41:29
No answer here - just another question. I didn't know about changing both bulbs either. I have 4 old 96" lights in my shop and 2 new ones. What makes them buzz? It affects the radio, too. Do I need to change out all the old ballasts? Thanks!
Gary from Muleshoe
11-24-2007 06:12:38
 Re: another electrical question (florescent light) in reply to Bud in WV, 11-24-2007 04:28:51
Bob The buzzing is most likely the ballast, it is on it's way to going out one day. It may very well last several years that way but the buzzing can be irritating.
buickanddeere
11-23-2007 19:33:28
Has somebody previously replaced just one lamp in that fixture instead of both. One old and one new lamp causes the ballast to overheat.
ldj
11-23-2007 20:13:50
 Re: another electrical question (florescent light) in reply to buickanddeere, 11-23-2007 19:33:28
To buickanddeere,
Yep, I did. It was probably 7 years ago or so. The way you talk that is a no no. I didn't know anything was wrong with that. Does that pretty well chinch that the ballast is bad?
buickanddeere
11-24-2007 07:12:56
 Re: another electrical question (florescent light) in reply to ldj, 11-23-2007 20:13:50
Toast.
Gary from Muleshoe
11-23-2007 16:54:54
Change both bulbs, if they still don't work change the ballast. Most of the 96" require both bulbs to be good in order for them to burn correctly. This problem you described is most likely the ballast. I always replace the bulbs also when I replace a ballast, especially if they are dark on the ends.
Bus Driver
11-23-2007 16:36:40
If the tubes have just one pin on each end, the ballast is "series wired". Removing a tube in that type fixture shuts off power to the ballast. With bi-pin tubes, removing one tube INCREASES the power drawn by the ballast and rapidly causes ballast overheating. I suspect that your ballast is failing. Can you try your tubes in a different fixture?
RobMD
11-23-2007 15:56:49
could be that you need new end caps. either that or your transformer is half shot.
Goose
11-23-2007 15:51:41
A bad wiring connection inside the fixture or a bad ballast, maybe?
