Consider anything you may want in the future, that would have to be under the slab or penetrating it, like the pex for heating, just cap the ends etc. It's good to check these things off your list prior to, as chopping out concrete later is obviously something to avoid whenever possible. Drains, electrical, heating and any other potential considerations for future use is smart to figure out now and do the necessary work leaving it for future reference Beyond that, your concrete supplier should probably be able to provide an admixture to the mix design to prevent freezing. Concrete creates heat when curing, definitely pour early in the morning, it's the best time when cold out as daytime temperatures rise and you have natural light, use woven wire mesh 6" x 6", make sure it's centered in the slab thickness, not on the sub base or ground, pull up on it with a hook, end of a rake or other hand tool while pouring. #4 bars can be used around the perimeter or where you may have higher stress points, like at the entrance etc. Make sure your sub base is firmly compacted and not frozen when pouring, after finishing, you can use thermal blankets to cover the slab to prevent freezing, talk to the supplier about the temperatures you are working in, right now around here, it's 30's-40's, not a problem to pour without any admixtures. 6" thickness would be better for dealing with heavier weights, but properly reinforced with woven wire mesh and or deformed metal bars (rebar), using a 4000 psi mix design at 4" may do the job, but you need to make sure it's well reinforced, I'd prefer 6" 3000 - 4000 psi mix design with substantial reinforcing if live loads from tractors or heavier equipment will be placed on it, for just cars or smaller equipment it may not be necessary, if its a smaller sized slab, and you need a few extra yards for additional thickness, money well spent there. I used to beef up sidewalk slabs on job sites, when I knew construction traffic would be a factor after it's poured, to avoid fracturing and or failure, especially heading into cold weather with a completion date in that time frame whereas it would be impossible to re-pour it if it was damaged.
