Tool Talk Discussion Forum
Anyone know what 16 rims will fit David Bradley trailer?
Jim in NY
11-22-2007 10:12:55
i have an older DB AG utility trailer that has a large center rim hole that I need to match so I can have a spare just in case Murphy gets into the act.
It is a five bolt pattern but can't seem to find anything that will work and DB wheels can't be found -- i guess thet are out of business nowadays ?
Just thought perhaps someone knows what I don't ?
thanks for now.. JIM
George S. in the real NY
11-23-2007 13:42:14
 Re: Anyone know what 16 rims will fit David Bradley trailer? in reply to Jim in NY, 11-22-2007 10:12:55
I know where there is a wagon gear that has only 3 wheels on it. Friend has it. It has been missing the 4th wheel for 20 plus years. He hates to part with things but I can ask. Seems to me it was a david bradly. I got 2 rims/tires for late 50's / early 60's Ford 15 in, 5 hole, I have no foreseeable use for them. Get back to me. George S.
Don-Wi
11-22-2007 22:50:06
 Re: Anyone know what 16 rims will fit David Bradley trailer? in reply to 135 Fan, 11-22-2007 10:12:55
If only you weren't so far away.... If it's truely a 5 on 5 1/2 bolt pattern, that's the common and standard size now a days. We've got a coulpe 16" 5 on 5 1/2" rims around the farm, and I even have 2 older 16" Ford 5 on 5 1/2" rims that we don't use on anything. I think neither one has a tire on either. I know 1 for sure doesn't.
Otherwise M.E. Miller Tire sells rims, and they have several different diameter patterns for 5 bolt rims.
Link
Donovan from Wisconsin
DAle B
11-22-2007 11:26:43
Old '60's Jeep wheels had the Ford PU hole pattern but a larger center hole. Trace the pattern on a cardboard disc and hit the junkyards. Worked for me.
CENTAUR
11-22-2007 11:16:55
There is a very good site that I found a lot of good WHEEL,RIM,and so forth info on.(carbibles.com) CENTAUR
MIKE FRENCH
11-22-2007 11:08:15
On DB running gears I always use Ford 5 hole pickup wheels, seems the originals are always rusted out, hope this helps Mike
jim in NY
11-22-2007 17:41:01
 Re: Anyone know what 16 rims will fit David Bradley trailer? in reply to MIKE FRENCH, 11-22-2007 11:08:15
Mike: do you happen to remember the vintage/year of the ford PU rims that I need?
Lumpy
11-22-2007 19:45:53
 Re: Anyone know what 16 rims will fit David Bradley trailer? in reply to jim in NY, 11-22-2007 17:41:01
I'm not Mike, but I may be able to answer you question. The rims Mike is refering to came off of '74 thru early '80's Ford f150, bronco, and e150 vans. These rims however are 15" NOT 16". The bolt pattern is referred to as a 5 on 5-1/2" bolt circle. DO NOT! let someone tell you that the ford car, such as a LTD, is the same wheel... it isn't! As someone else said, trace onto a piece of card board and go searching. They should be about $5.00 each.
jim in ny
11-23-2007 18:51:13
 Re: Anyone know what 16 rims will fit David Bradley trailer? in reply to Lumpy, 11-22-2007 19:45:53
thanks "not Mike" i appreciate your help too....
