Tool Talk Discussion Forum
Need 5/8 allen wrench
Boyd in Mn
11-20-2007 10:11:55
I'm scrapping a chevy TBI aluminum intake. I need to remove the allen type plugs on it first. One big one is 5/8". I've tried Menards, Sears and auto parts stores with no luck.
Bud in WV
11-21-2007 16:27:23
 Re: Need 5/8 allen wrench in reply to Boyd in Mn, 11-20-2007 10:11:55
I used to plan turbine generator outages. The best supplier I've used is MSC -
Link
If they ain't got it, you don't need it! Before you order, be sure you want it "tomorrow" 'cause that's when it'll get to you. Shipping ain't cheap but if you gotta have it, they'll come through!
dr. sportster
11-21-2007 13:42:52
Sometimes one of your chisels will fit if its a hex shank.Did that for the rare 7/16s allen screw.
ray_woods
11-21-2007 06:45:09
Hex head bolt.Use the head side double nut the threaded side --socket and ratchet to get out. Might need to hit the bolt head on a belt sander.
Gerald J.
11-20-2007 19:46:17
Break it through the plugs, then they will almost fall out.
Gerald J.
flying belgian
11-20-2007 18:52:15
Weld a nut on it.
msb
11-20-2007 16:46:20
I have , on occasion, used a hex shaped punch and a Crescent wrench when in a pinch.
Lefty
11-20-2007 15:52:34
Can ya trot the manifold down to yer local GM dealer and beg a favor?....Call first.It might be metric too!
Wardner
11-20-2007 15:18:33
How about painting the plug with aluminum paint. LOL
It's shame you are not a neighbor. I have a bucket with at least 100 large allen wrenches. The biggest being well over an inch. I actually use them once or twice a year.
Gerald J.
11-20-2007 11:03:10
Check your local hardware store for a coupling nut thats 5/8", might be threaded 7/16". Stuff it into a 5/8" socket or box end.
Gerald J.
ed19
11-20-2007 10:52:26
Your napa store would have it.
old
11-20-2007 10:46:35
What I have done in the past is take a 5/8 bolt and then take a nut and weld it on the bolt. Then you can drop the heard of the bolt in the allen and take a socket and take it out that way. Simple cheap and using a socket you can a good handle to work with
pair-a-dice farm
11-20-2007 17:32:38
 Re: Need 5/8 allen wrench in reply to old, 11-20-2007 10:46:35
Yep that'll work. I bet I've got a tool box full of home made tools. Most of the time they work just as good as store bought, somtimes better.
Chvet73
11-20-2007 10:33:37
McMaster-Carr has them. Look for hex keys. I just checked.
Bob
11-20-2007 11:17:56
 Re: Need 5/8 allen wrench in reply to Chvet73, 11-20-2007 10:33:37
I'll BET it'll take scrapping SEVERAL aluminum manifolds to pay for a 5/8" Allen wrench, at least a QUALITY one!
RobMD
11-20-2007 13:43:32
 Re: Need 5/8 allen wrench in reply to Bob, 11-20-2007 11:17:56
bada bing! somebody better start thinking...
Chvet73
11-20-2007 10:33:36
Chvet73
11-20-2007 10:33:27
GeneMO
11-20-2007 10:27:33
Can you find a bolt that will fit in there? Head first, then weld a cross piece on out of any scrap handy.
Gene
Wisconsin Cowman
11-20-2007 10:18:54
You would be better off getting an allen head socket. I know Sears sells them cause I Got a 9/16 and 5/8. Snap-on has them too. I don't think I ever saw a 5/8 allen head wrench before.
44 massey
11-20-2007 10:16:53
If you have an iron dealer close go and see if he has any 5/8 hex shaft and make your own or just put it in a 6pt 5/8 socket.
