Compression leakdown tester
Don
07-10-2001 16:02:41
I thought about making an engine compression tester, but was told that i should make a leak down tester as this is more sensible on a diesel engine. could any one tell me if i could make one out of a tyre pump, tap and a decent gauge, and if so what pressures should i use and how should i interpret the results? thanks for your help.
bob w.
07-19-2001 21:04:57
 Re: Compression leakdown tester in reply to Don, 07-10-2001 16:02:41
i allways like to take a compression test first and if there is a problem then i would just shoot shop air into the cylinder and see where the leakage is from to futher diagnose the problem.
lust my two cents worth.
Franz
07-10-2001 19:33:34
There seem to be a couple or 3 going across Ebay every week, and they ain't bringing a whole lot of money.
Dean
07-10-2001 16:34:10
NAPA and other auto parts store sell them and they come with instructions. Actually, to do the job right, you need both a compression tester and a cylinder leakdown tester.
