Tool Talk Discussion Forum
Hydraulic Cylinder Settles
Glenn FitzGeral
11-19-2007 13:32:40
The last job I used my cherry picker for was a little too much for it. It now settles gradually. There are no external leaks. What is likely the problem? The unit is about two years old and otherwise in excellent condition. Did I blow an o-ring or something?
Thanks,
Glenn
135 Fan
11-19-2007 14:19:30
 Re: Hydraulic Cylinder Settles in reply to Glenn FitzGerald, 11-19-2007 13:32:40
The internal seals on the piston are most likely your problem. When you say cherry picker, do you mean manual engine hoist? or is it a cherry picker with a powered hydraulic system? dave
Glenn F.
11-19-2007 15:53:30
 Re: Hydraulic Cylinder Settles in reply to 135 Fan, 11-19-2007 14:19:30
It is a manual engine hoist. "Jack" lifts on the down stroke.
Glenn
old
11-19-2007 17:58:50
 Re: Hydraulic Cylinder Settles in reply to Glenn F., 11-19-2007 15:53:30
Most likely blew the o-ring/seal on the internal piston. Depending on what it is/who made it it could be a simple fix or a real pain in the #$$ if its a cheap one.
