Tool Talk Discussion Forum
Multi-Meters Cold Weather
Glenn F.
11-18-2007 09:45:14
I have a couple cheepie digital multi-meters which I have always kept in the house in the winter (NE WI). I'd like to keep them in the shop, which is not always heated. Will they withstand the cold...at times below zero?
Thanks,
Glenn F.
Jerry/MT
11-18-2007 17:24:13
 Re: Multi-Meters Cold Weather in reply to Glenn F., 11-18-2007 09:45:14
The LCD display doesn"t work when they get cold. I quit using them around old tractors for that reason and because they don"t have stable readings I guess due to to RF interference from the ignition wiring. I use analog meters.
Red Dave
11-18-2007 11:50:57
I keep a cheap one in my tools that I carry around all year long. Have for years. Should be no problem, keep a spare battery with it. You may have to stick it inside your shirt for a couple minutes on really cold days to make the diplay work, but I don't think it will do it any lasting harm. To you or the meter.
CH(upstate, NY)
11-18-2007 10:51:58
Don't get nervous if the displays don't work. LCDs don't work when they're cold.
Bob
11-18-2007 10:01:48
Yes.
The batteries may be a little weak when it's REALLY cold, though.
Glenn F.
11-18-2007 10:30:44
 Re: Multi-Meters Cold Weather in reply to Bob, 11-18-2007 10:01:48
Thank you
