Tool Talk Discussion Forum
Wiring Question
newtothisgame
11-17-2007 19:56:32
im going to switch a panal from fuse to circit breaker and i am wondering with the new code about AFCI breakers i have one whole floor on one fuse its 1 bedroom living room and a bathroom do i need to put in an AFCI cuz its a bedroom involved and put GFCI Recep in bathroom or regular breaker and just GF in bath thanks for any help
dave guest
11-25-2007 17:36:51
 Re: Wiring Question in reply to newtothisgame, 11-17-2007 19:56:32
If you are changing panel, make sure all your service entry cable is adequate size for replacement. In otherwords, call the inspector. Some insurance companies have refused claims based on lack of authorized work. End of story.
El Toro
11-19-2007 07:49:03
I would ask around from your friends or neighbors and find a licensed electrician and have him install that panel. The meter will have to be pulled to kill the power and then it will need to be sealed. Hal
Charles (in GA)
11-19-2007 05:41:50
The catch here is that the AFCI by code must be at the panel or within 6 ft of the panel and only connected by metal raceway to the panel, and thus you will have a GFCI receptacle being protected by a AFCI breaker if you had one combined circuit. I don't think you want the GFCI to have anything before it except a regular circuit breaker, the AFCI could easily affect the operation of the GFCI, resulting in one or the other of them tripping all the time. Even GFCI receptacle instructions tell you to not install in a circuit protected by other GFCI's for this reason.
Really need to separate the circuits. Indeed I don't think the code would require the AFCI or even the GFCI to be installed due to a mere panel replacement, however this is the ideal time to take a few simple safety measures.
My experience with panel replacement is that the wires in the old panel are always too short to reach where they need to in the new panel, usually due to the new panel's larger size and isolated neutral/gound, and I still ended up running new wire back to the first device in the circuit, or further.
Charles
Dusty MI
11-18-2007 19:42:09
I could be wrong but if you are only changing the panel and not doing a remodel just do the panel and change the rest when you do the remodel. It is better to have everything up to todays code, but the code only requires up dating when doing a remodel.
Dusty
Charles (in GA)
11-18-2007 13:34:14
2005 NEC 210.11(C)(3) forbids a branch circuit feeding bathroom(s) receptacles, from feeding anything else outside a bathroom.
The bathroom circuit may feed receptacles and other equipment, such as fans, if it only feeds ONE bathroom, or the branch circuit may feed multiple bathrooms, receptacles ONLY, but in any case, may NOT feed equipment or lighting or receptacles other than bathrooms.
In "An Illustrated Guide to the NEC" Charles Miller illustrates all the different allowed and not allowed combinations on page 128.
Charles
John T
11-18-2007 16:23:29
 Re: Wiring Question in reply to Charles (in GA), 11-18-2007 13:34:14
Thanks, that confirms my thoughts, I really didnt like the sound of feeding BOTH a bath n a bedroom on a single branch circuit
John T (long retired EE)
John T
11-17-2007 20:47:13
Although Im knee deep in theory, as a long retired electrical design engineer Im rusty as an old barn nail on the NEC, but will give ya my best shot. Okay, its indeed true the bathroom requires GFCI just as you stated AND its also true a bedroom requires AFCI buttttt ttttt t I really have heartburn with feeding BOTH those rooms with only one branch circuit and recommend it not be done, i.e. Id upgrade so each is on its own (AFCI or GFCI) branch circuit breaker.
I guess if the AFCI and GFCI requirements were BOTH satisfied, it doesnt hurt if either room had a double degree of protection (AF + GF protection) but I still dont like it lol
HOWEVER,,,,, ,IF YOU INSIST ON ONLY ONE BRANCH CIRCUIT use an AFCI circuit breaker (to satisfy the bedroom requirement) in the panel and then when you get to the bathroom first use a GFCI outlet and feed the other loads downstream off the GFCI which would give you double (AF + GF) protection in the bath, but Im unsure what the NEC says (I STILL DONT LIKE THAT AND PREFER EACH ON ITS OWN BRANCH CIRCUIT)
I know fer sure (sounds like you did already) you are NEC correct with GFCI in the bath and AFCI in the bedroom and each on its own branch circuit, but until someone who is more NEC current then myself can establish its okay to use an AFCI breaker to feed the bedroom and then take that same branch circuit n run to a bath using a GFCI, Id be nervous about doing it myself.
Its your house n your life n your call I reckon but I cant sit here n tell ya the NEC will allow that AFCI and GFCI scheme described above, maybe someone else can and even cite you the section????? ? My NEC book is too old for that AFCI requirement....
John T (tooooo long retired)
