Tool Talk Discussion Forum
Arrrghhh
JoeK(WI)
11-17-2007 08:21:45
Renovating an ancient boat trailer,went to get wheel bearing seals....$12.60ea!!(my cost) Retail at $15.??ea!Typical seal,nothing special,cept slightly bigger than common ones.Might just pass this project on down the line.:(
Shoulda checked before stripping,painting,tires &lights/wiring.Profit margin just plunged to"not today" range.
circus
11-18-2007 07:15:51
 Re: Arrrghhh in reply to JoeK(WI), 11-17-2007 08:21:45
Was quote $160 for a small spin on oil filter for my compressor. Required replacement every 300 hours. Arrgh.
rockyhawaii
11-17-2007 14:49:35
The price of oil is driving everything up, from property leases to shipping to electricity. We'd all better get used to it because it's only going to get worse.
Fawteen
11-17-2007 10:16:03
We priced a mechanical seal for the shaft on a feedwater pump. $487+ for two ceramic rings, a rubber doodad and a spring...
Spook
11-18-2007 19:03:49
 Re: Arrrghhh in reply to Fawteen, 11-17-2007 10:16:03
We use a lot of pumps for coolant and lube on our production machinery. We have our own pump shop. We seldom rebuild pumps anymore. The manufacturers have priced rebuild kits so high that it is cheaper to buy new. On some small models the kit is actually more expensive than a new pump. Same thing with hydraulic cylinders.
WV2cyl-L
11-18-2007 05:41:14
Email me, I think those things are less than 20.00 around here, I do a lot of pump repairs and use them from occasionally on the old jet pumps
135 Fan
11-17-2007 10:20:02
Those doodads will suck you dry. Dave
Bob
11-17-2007 09:13:07
I priced a CR seal for a PS pump a few days ago, jusy a little seal, .625" X 1.25", or thereabouts... almost $13.00. That is for a pretty generic seal.
I had the Edelman number from a PS kit book, and had the jobber check that number... some $3.00, ordered in a a stock order. Since I use those from time to time, I had them order 4. They are VERY nice seals, with a rubber sealing area on the OUSTSIDE to seal to the bore, just like OEM.
APPARENTLY, SKF/CR is getting a bit greedy!
