Tool Talk Discussion Forum
Truck Storage
Ted in NE OH
11-15-2007 12:54:52
I am going to put my PU truck in the gararge for the winter. Do I change the oil before storage or after storage ??
Mike M
11-16-2007 05:35:07
 Re: Truck Storage in reply to Ted in NE OH, 11-15-2007 12:54:52
That's only 6 months max. I wouldn't get too worried about it. Dads 1981 F350 sits all winter so it stays out of the salt,and usually doesn't even get ran. Been doing it for many many years now and never had a problem. The engine oil is never real old it but not new either. This in also in Northern Ohio.
Leland
11-15-2007 19:31:53
best thing to do if possible is once a month start it up and drive it about 10 miles to warm it up and get it hot enough to evaporite the water from it .
old
11-15-2007 15:43:48
Change oil before and also put a little tranny fluid or oil in the cylinders. That way if any of the valves are open which they will be its less likely to rust and or lock up on you
dhermesc
11-15-2007 13:03:22
Before.
Dirty oil combined with water from sitting is very hard on engine parts. Best thing to do is fill it with synthetic before it sits. Even if water condenses in the oil pan synthetic oil won't turn into sludge when you start running it again in the spring.
