Tool Talk Discussion Forum
what is this tool??pvc pipe bender
maplehillfrm,pat
11-15-2007 06:45:56
third party image
I have this tool I found in my shed, I probably got it from an auction, any idea what it is? I was told a pvc pipe bender, it looks like it could be, ,,
propane gas hook up in the handle, and heating elements in the body???
BobReeves
11-16-2007 14:33:01
 Re: what is this tool??pvc pipe bender in reply to maplehillfrm,pat, 11-15-2007 06:45:56
It's for joining the connectors on the yellow plastic gas line used almost everywhere these days. You heat it up with a propane torch and it forms the plastic around the fitting.. Seen it used when the guy ran the lines for our propane tank.
Vern-MI
11-15-2007 10:48:20
Intake air heater for cold climates???
135 Fan
11-15-2007 10:09:25
If it doesn't have a direct flame inside it might be for bending PVC. I've seen something like that before. It might also be for butting ends together and welding them. Dave
cactus farmer
11-15-2007 09:29:51
Large hot dog cooker?
ddd
11-15-2007 09:26:29
pvc pipe burns under direct flame. No way on the pvc pipe. More than likely used to heat up copper or cast pipe to soldier a flange on it.
maplehillfrm,pat---pictur
11-15-2007 06:47:43
third party image
another shot
Bob
11-15-2007 07:02:28
 Plumber's torch? in reply to maplehillfrm,pat---pictur, 11-15-2007 06:47:43
POSSIBLY to heat up large-diameter copper pipe for soldering?
