trucker40
11-15-2007 19:58:46
Re: Welder in reply to Allan In NE, 11-14-2007 02:13:11
I would see who I was going to get to supply me gas bottles,ask them what they carry parts for,and if they have a deal on something.If you can get tips,liners,and talk to people that have a welder like that and get good recomendations,and it seems like a good price to you buy that.Ive used lots of different kinds,Miller,Hobart,Lincoln and they all work good.I own a HTP because I got a good deal on it,and I like it real well.The big thing you have to watch is on the cheaper stuff is the duty cycle,does it have a cooling fan,is the wire hot all the time,can you buy tips for it,can you buy a liner for it without having to order it.How much will you use it,can you weld with a mig,all that makes a difference. Ive seen guys cuss a brand new welder and not use it because they didnt get on to it right away.After a while somebody would start running it and figure it out,then the guy cussing it would want it.Usually the operator has a lot to do with it,how you set it,on a mig,is a lot of it.Then for me it would be how much it costs.If you can buy a welder for a thousand dollars that can do what you want it to,why buy a welder for eighteen hundred that has a name on that somebody suggests.Even a used one if its got everything with it because you really need a book for it. If you are going to run it night and day,make a living with it,then you may want to come up with the extra for the new welder,but if you are going to use it now and then,maybe dont know all that much about a mig,why buy the high dollar one.New is fine,but 200,400,800 dollars will buy a lot of welding wire,and gas is getting higher all the time.Contrary to what some say,CO2 works just as good in most cases as argon mix.I could be wrong,but I thought Argon mix was mostly for welding on newer car sheet metal.I know I have welded a bunch of stuff in my life with CO2,and about all you need to do is keep the wind from blowing it away somehow.
