Tool Talk Discussion Forum
Hydraulic jack problems
JD 4020 and A o
11-13-2007 22:42:36
so yeah, was trying to use my hydraulic jack to raise my plow i am restoring and found out that it will only go up about 1 1/4 of an inch. family member used it prior on another job... i looked at where it was sitting and there was a pool of oil around it. so i am guessing it came out of the release valve that might not have gotten retightened??? If thats the case, how do i go about putting more oil in. Help, because im going to have to use it here soon for other jobs.
Vern-MI
11-14-2007 04:23:40
 Re: Hydraulic jack problems in reply to JD 4020 and A owner, 11-13-2007 22:42:36
Floor jack or bottle jack, old Hein Werner or newer Asian model?
The bottle jack usually has either a rubber or threaded steel plug on the side of the "Bottle" that you can remove and fill up to the fill hole.
Floor jacks are similar to the bottle jack except that the "Bottle is laying horizontal. Some of these have a fill plug on the side of the bottle and some have the fill hole in the pump base section. These have to be filled by removing a 1/4-20 screw at the base while holding the floor jack in the verticle position with the saddle at the lower end.
You can use regular or synthetic power steering fluid to fill these so that they will work better in colder temperatures.
Don't ever wash a floor jack with water or leave it out in the rain as the water will get into the pump plunger bore and cause corrosion and leakage.
JD 4020 and A owner
11-14-2007 15:06:02
 Re: Hydraulic jack problems in reply to Vern-MI, 11-14-2007 04:23:40
its a bottle jack, thanks for the reply i will take a look and see
