Tool Talk Discussion Forum
Sweat furnace
x22
11-11-2007 15:23:30
Can an individual run a backyard sweat furnace without having to meet the requirements of the state and federal regulatory agencies?
Spook
11-11-2007 20:48:07
 Re: Sweat furnace in reply to x22, 11-11-2007 15:23:30
You would have to get the lawnmower parts to at least 1400 degrees, maybe more depending on the alloy. A small furnace, fired only occasionally would not be very efficient, it would take a lot of energy to run, either gas or electric. And that would be pretty expensive. And it would be pretty time consuming, so what's your time worth? I think a wood fired furnace would be hard to control the heat in. And even if you got ignots, the result would not be pure aluminmum. The castings are some combo of zinc, and other metals, some of which might give you some nasty fumes. Another thing is, a lot of these castings have as much as 30% silicon in the alloy, which is worth about zilch. All told, I wouldn't bother.
Midwest redneck
11-11-2007 18:20:28
Of what purpose would you want to melt aluminum ingots? Are you starting an aluminum foundry?
x22
11-11-2007 19:00:09
 Re: Sweat furnace in reply to Midwest redneck, 11-11-2007 18:20:28
This is a way to recycle aluminum. If the aluminum is in ingot form, it is worth a lot more than irony aluminum (lawnmower engines).
Midwest redneck
11-11-2007 16:49:59
What is a sweat furnace?
x22
11-11-2007 17:25:43
 Re: Sweat furnace in reply to Midwest redneck, 11-11-2007 16:49:59
Its a furnace that makes you sweat.LOL Really it is a type of blast furnace used to melt aluminum that has iron mixed with it (like lawn mower engines) into ingots of nearly pure aluminum.
Uncle Ernie
11-11-2007 15:57:15
You can do anything you want. Getting caught is another matter...
x22
11-11-2007 16:28:56
 Re: Sweat furnace in reply to Uncle Ernie, 11-11-2007 15:57:15
I think small businesses with fewer than 5 employees should be exempt from these stifling regulations.
JoeK(WI)
11-12-2007 19:49:23
 Re: Sweat furnace in reply to x22, 11-11-2007 16:28:56
Local junkyard(family operation)in middle of nowhere built a LP fired sweat smelter a few yrs back,figuring he'd do much better on aluminum,zinc,lead etc...He found with the extra work,cost of gas,time he was really not gaining much....also did have visit from Gov't,sicced on him by competitor.Whats left of his smelter still sits there,with a good sized aluminum"turd" hanging from the sprue.
Research carefully before investing any $$$
