Hi Gary, I use a cleaning method simular to jCarrol but remove the drain valve from the tank as the drain valve is the lowest point on the tank. After the DV is removed, I use a 1/8" SS filler rod very gently, in and out motion, while the water is turned on. Be very careful on glass lined tanks as not to crack the glass as you use the rod. Repeat this motion until the water is running fairly clean of calcuim (white in color). This allows for alot of the calcuim deposts to be removed from the tank. After cleaning with the rod, I reinstall the DV then add a cup of bleach to the tank, then fill the tank and water pipes with water until the faucets (all of them) smell of chorline then let this mix sit over night then drain the tank then run the faucets until no chorline smell. I keep the wife out of the room while running each faucet as then she can smell if chlorine is still present at the tap. Since I'm waiting for the line to clear, my smeller gets accustomed to the smell of high chlorine content and I can't tell when the tap runs totaly clear of chlorine. This is also a good time to replace the T&P safety valve if it has been weeping. I do not use a Aluminum anode rod in my HW tanks, nor cook with AL pans or drink water from AL, as AL is known to cause altimers(sp?) disease. If you clean the water system twice a year, once in the spring and fall, then you will always have good tasting water with no rotten egg smell. T_Bone
