Tool Talk Discussion Forum
6 Volt Timing Light?
Alex In Texas
11-09-2007 22:04:46
Does anyone know where I can find a timing light that will work on an engine with a 6 volt ingition system?
WeirdDeere
11-13-2007 02:24:24
 Re: 6 Volt Timing Light? in reply to Alex In Texas, 11-09-2007 22:04:46
Am I stupid? I've used a 12 volt timing light on a couple 6 volt engines with no problem. Hooked right to the 6 volt battery (and the #1 wire), and it worked fine?!?!? Maybe a bit dim, but no big deal?
Brandon
john *.?-!.* cub owner
11-11-2007 19:09:14
 Re: 6 Volt Timing Light? in reply to Bob, 11-09-2007 22:04:46
I use one of the booster packs to power my 12 volt light when working on my 6 volt stuff.
Charles (in GA)
11-10-2007 02:18:14
Any ordinary 12v powered timing light will work, but you need an independent 12v power source. Simply pull you riding lawnmower up next to the car or tractor you are checking the timing on and clip the lights power leads onto the 12V battery, clip the pickup lead on the #1 plug lead of the vehicle you are checking the timing on, and you are done.
Charles
ldj
11-10-2007 06:21:25
 Re: 6 Volt Timing Light? in reply to Charles (in GA), 11-10-2007 02:18:14
I have a timing that is so old it was probably built when George Washington was a Corporal. It uses 110v ac. I have searched and can't find that anyone still makes a 110v timing light.
T_Bone
11-11-2007 21:12:19
 Re: 6 Volt Timing Light? in reply to ldj, 11-10-2007 06:21:25
Now that's old.....LMAO
T_Bone
Bob
11-10-2007 06:32:14
Mowadays, they make timing lights tthat run off of internal batteries.
Even HANDIER than AC powered units, IMHO.
Charles (in GA)
11-10-2007 15:55:47
 Re: 6 Volt Timing Light? in reply to Bob, 11-10-2007 06:32:14
I have a neon one that was my dads, it wires inline with the plug wire, no other power needed, but doesn't generate much light either. I have two similar Sears strobe guns, one is a clamp on the plug wire induction type, the other uses a wound spring extension you put on the plug and hook the plug wire back on, and clip on this to the spark signal. Both are 12v powered and I have used them on a 6v ford tractor by pulling the 12v lawn mower up beside the tractor and clipping the power leads on the mower battery.
Charles
Alex In Texas
11-11-2007 19:02:27
 Re: 6 Volt Timing Light? in reply to Charles (in GA), 11-10-2007 15:55:47
OK, I did not realize it was that simple. I feel kinda stupid now. Thanks for the info George.
