Tool Talk Discussion Forum
CEN-TECH Multimeters
Glenn FitzGeral
11-09-2007 06:29:44
Over the years I have bought two Harbor Freight CEN-TECH multimeters when they were on sale. (I think I have about $6.00 invested.) The model numbers are 90899 and P33499. Model # 90899 is a 7 function unit: DC Voltage, DC Current, AC Voltage, Resistance, Transistor Test, Diode Test, & Battery Test. Model P33499 tests: DC Voltage, AC Voltage, DC Current, Resistance and Diode Test.
My knowledge of electronics is pretty limited. I'm always gonna sit down and educate myself someday...
Just curious; do any of you have one of these meters? Are they very useful?
Thanks,
Glenn F.
MF294-4
11-10-2007 18:28:34
 Re: CEN-TECH Multimeters in reply to Glenn FitzGerald, 11-09-2007 06:29:44
I'm like the others. I keep my good meters in reserve for critical measurments. Have about half dozen cen-tech meters. Usually don't need a lot of accuracy. Gave one to my brother and one to my son so they don't call me so often. I don't think i would use my cen-tech on 440 like some of the others said. The only other meter I use as much is a DC clamp on amp meter.
farmer boy
11-10-2007 09:52:38
I bought one at an auction sale a month ago or something very similar. Was like new. Only used a few times. Not much use for it,just nice to have if you ever do need it. Paid $10 for it.
CRUSADER
11-10-2007 06:07:21
I'm not a fan of harbor frieght tools, although there are a couple of things I'll most likely be buying from there in the near future. I've got an analog meter that I got at Sears about 12 years ago...was broke but needed a meter. It works just fine for what I use it for. I also have a digital meter I bought from Sears, don't think I could buy one as good for what I might need for less than I paid for it ($9.00). These lower cost meters usually will serve well for most applications. At work, we use fluke meters, but I don't plan on working on very many weapon systems or aircraft in my spare time or after I retire.
Jim
Jeff-oh
11-09-2007 15:32:57
I have two of the meters you describe. Love them. At $3.00 it has all the funcctionality you need for working on old tractors.
They are also pretty tough. I had smoke pouring out of one of them once and it still works. (wrong settings).
I also like the size as I keep one in the tool box on the tractor and another in the tool box in the shed.
lucas boy
11-09-2007 12:35:13
i was at harbor freight yesterday and they had multimeters for 1.95 , i think they were cen tek brand .i didnt get one .i have a few allready and they work. ot.. i got a air die grinder for 5.00 , air ratchet for 10.00 , car coil spring compressor for 9.99, 500 piece cotter pin set for 2.63 , sawzall for 15.00 ,bunch of small things for .79 cents . i know its junk but i dont sawzall that often... lucas
tech4
11-09-2007 12:05:27
 Re: CEN-TECH Multimeter's in reply to Glenn FitzGerald, 11-09-2007 06:29:44
Just judging by your question I will assume that you do not have any electrical experience or electrical background but a desire to learn. A cheap meter such as that is a very good learning meter. Even those of us that work with electronics and electricity every day make mistakes and occasionally blow a meter. It sure hurts when it is one of the expensive Flukes or older Hewlett Packards. One of the common problems is trying to read AC voltage on the ohms or milliampere scales (forget to switch) Some of the newer meters do have some protection but stuff happens. Radio Shack did have a nice book on using Multimeter's that was very useful. You might read up on that and some very basic electrical texts and then when you get more proficient you might want a better meter. I keep one of the cheapies in each toolbox and one in each car and truck.
T_Bone
11-10-2007 10:53:20
 Re: CEN-TECH Multimeter's in reply to tech4, 11-09-2007 12:05:27
Hi Glen,
I too have bought 6 of the $3eh meters for using with my RV and pick-up/cars as mine read DC voltage but they will not read AC voltage, 3 meters so far.
I always test each meter with a new AA battery to see if the meter is reading accurate.
For a cheap meter that I don't care if it gets broken, there worth $3eh. I keep my good DVOM in a case on foam rubber so it doesn't get broken from the road viberations.
T_Bone
Dick L
11-09-2007 10:17:48
I have been buying the cheap ones at Radio Shack for years to use out in the factory. They are plenty good enough for checking fuses and to see if you have 440-220-or 110. I keep the better insturments in the office and make sure I know who is going to be using them. Still loose a good one now and then to someone forgeting to turn the dial.
Stan in Oly, WA
11-09-2007 09:50:27
Hi Glenn,
I'll go along with what previous posters have said, those cheap VOM's are useful for testing a few basic functions. I have two suggestions about using any type or brand of electrical circuit diagnostic equipment: 1.When testing for voltage, make sure you get a reading somewhere before assuming that there's no current in the line you're testing just because the test unit didn't show any. Particularly with the cheesey leads of those cheap units, you need to be sure that it's going to register voltage if there is some; there's an importance difference between a line with no current and one where a malfunctioning machine fails to show current. 2. The second most common way I use such a meter is to test continuity in house wiring when troubleshooting an electrical problem. Again, touch the leads together after you set it for ohms to make sure you can get a reading. Resistance readings depend on the unit's battery as well as the leads being connected. Here's the suggestion that makes this procedure more useful: (Test continuity with the circuit turned off.) You can use an extension cord to extend the wire you want to find the other end of. Hook the wire through the hole in one of the prongs of an extension cord (or shove it into one of the slots of the other end); test for continuity, which will also reveal which conductor you're using (the ground would be better since it's always obvious at both ends, but the ground prong never has a hole through it); once you've established which conductor to use, you can take your meter and the end of the extension cord to the location where you need to find the other end of the wire. Of course this would be easier and work better with a length of bell wire with alligator clips at each end but you'll never get around to making that, and if you did you'd never have it with you when you needed it. You'll always have an extension cord, though.
All the best, Stan
Mattlt
11-09-2007 09:39:16
I ordered one of the cheapies several years ago. When I got it, the LED display didn't work correctly. I called to complain, they sent me a new one; didn't even want the old one sent back. (That should tell you how cheap they are)
After tinkering with the faulty one, I found that pinching the case together with a well-placed piece of tape was all that was needed. Both are still working. Good enough for what I need them for.
old
11-09-2007 08:42:11
I have one of there Chicago electric meters I use off and on and it seems to be just fine for most stuff model #7517. I've had it for more then 10 years now and its nice to have around but I don't use it much. Most of the time I can do a spark test with out a meter and figure out where the problem is any how so the meter stays in the house. LOL
Coloken
11-09-2007 07:54:30
Good enough for many things. A lot of times all you need to know is if a voltage is there, and some times, its aproximate value. Most other times you want to know if a circuit or connection is there (shorted) or open. Thats about it 95 percent of the time.
Bob - MI
11-09-2007 07:54:27
I have 2 of them and for the price on sale thay are just fine for me. My electrical skills are limited but for checking the simple stuff they work well.
I just put a battery in my oldest one after enough years that I can't remember when I got it. Sticker on the outside warns that there's no user serviceable parts inside. Apparently they don't know how to change a 9-volt over in China.
wfw
11-09-2007 07:19:26
If it is the same one Ive got then it is a good little toolbox meter, works pretty well, not as accurate as my fluke, but for the price is ok. I figured whenever it got broken I would not be out of much because it was so cheap, where as if my fluke got broken in the toolbox I would have to pay dearly for it. I love the fluke meter btw.
KEB
11-09-2007 07:15:58
I have a couple of their cheapies. Other than the flimsy leads, they're about as useful as any other digital multi-meter, and they're cheap enough that if one gets damaged its no big deal. I also have a high quality Fluke, and a couple laboratory grade analog meters.
I haven't tried to check the calibration against a good meter, but then again I don't use them for anything that would require accurate calibration. I suspect they're not true RMS on AC, again no big deal for simply determing if there's power present or not.
Keith
JoeK(WI)
11-09-2007 09:12:00
 Multimeters/etc in reply to KEB, 11-09-2007 07:15:58
Local electronics recycling plant gets lots of used test equipment in.They try to sell the good stuff on Ebay after checking it out.Prices are very low(Bought a $200 brandname benchtop multimeter(less leads/book) awhile back for $14.99 and have made several other purchases of like nature.Lots of stuff goes thru their plant of interest to the tinkerer/Descriptions are accurate and tech doing checkout of items,knows his biz.Check em out on ebay under sellers"
therecyclequeen
worldrecycler
Note:I am not affiliated with or related to this seller in any way.Just giving a bargain heads-up
