Tool Talk Discussion Forum
New windows
higgins
11-08-2007 14:14:41
Anyone put in new thermal effecient windows over the last few years? Can you tell a difference in electric (or whatever) bill? The demos are impressive but the pitch is about like sweeper sales pitches....
higgins
11-09-2007 13:44:56
 Re: New windows in reply to higgins, 11-08-2007 14:14:41
Thanks for the informative replies. We can feel the breeze coming thru most of the old windows so it's about time to bite the bullet.
lucas boy
11-09-2007 12:27:36
i use window world in my rentals and had them put in here too. 189.00 for any size installed. hard,welded vinyle double pane,30.00 extra each for low e glass. lifetime warranty deal. my house is 100 years old frame. it helped alot. i used to feel wind blowing in here. i was buyin 2 pane windows for my rentals for about 300.00 each installing myself and they werent as good as window worlds window. i think the low e helps more in the summer than winter..my ex had windows put in her house for 500.00 each and she admitted they werent any better than window world windows. lucas
Mattlt
11-09-2007 06:05:25
Just my two cents. If you have excess moisture in the house, I'd recommend vinyl. In an older house you probably don't have problems with the lack of fresh air coming in, so I doubt it's a problem.
I hate having moisture on the windows.
molinebob
11-09-2007 01:04:19
I work for marvin windows and they do have a impressive product, They just won the J.D. Power and associates award for an outstanding product, Like the other guy said they are spendy but I thnik they are well worth the money, I think I would go with a double hung over a casemaster unit.
old timer in ohio
11-08-2007 20:30:15
Hey there Higgins;
You need to make the choice,do what you will.
We had 53-(fifty-three),new replacement windows
installed in this old house.Have they helped??
I think so,its quieter,less drafts etc.etc.Would
I do it again? YES!! STAY AWAY FROM ALUMINUM FRAMED windows. Aluminum is one of the best
materials for transfer of heat & cold you defeat
what you are trying to do, Bob
God Bless
Billy NY
11-09-2007 05:26:00
 Re: New windows in reply to old timer in ohio, 11-08-2007 20:30:15
The extrusion profiles of an aluminum framed metal will illustrated clearly if that window is thermally broken. There is a non conductive material within the aluminum extrusion framing member that is called a thermal break, it stops the transfer of cold or heat to the interior. These windows usually have an internal weep system, and can be finished with a very durable finish system like PPG's Duranar. Moduline and Wausau windows from Wisconsin are 2 premium aluminum window mandufacturers, mostly catering to the commercial building industry, they make a product that performs and has been tested by standards shown in the link I posted in my first thread. Both use Viracon glazing (glass) excellent products by these manufacturers. They also are expensive. Even in the residential and light commercial market, a competent storefront and glazing outfit can stick build from proven extrusion profiles, something that is thermally broken and will perform well, and there are lesser quality window lines that will perform to the needs of residential buildings, you just need to know what you are looking at to determine what will do the job.
I'll agreee though, if it's not a tested, reasonble quality manufactured and a thermally broken extrusion profile that the window is built from, it's most likely junk. The manufacturing process has to be top notch for these, when the machines and tooling for these kind of windows get sloppy or have problems, it can easily put a damper on the products performance. Usually tested in 2 ways, window by itself, and the window installed into a common or unique substrate, to determine how each performs, the latter being dependent on the installers work.
Long winded, but interesting stuff, don't let those amateur outfits fool you, some of the best windows made are aluminum, having been installed into buildings all over the country where there is no subsitute for meeting rigorous performance criteria.
RobMD
11-08-2007 20:22:30
they don't make a single darned difference if they were not properly insulated and sealed in the structure frame.
redtom
11-08-2007 19:55:25
My parents put in Marvin aluminum clad wood casement windows in their 1967 brick ranch about ten yrs ago. It easily cut 30 % off their bill. They weren't cheap but well worth it. I on the other hand, built my house in 93 and put in Caradco windows. I'm not sure they make them any more, (I hope they don't). They should be in jail for making windows like mine.
Jim Broughton
11-08-2007 18:59:14
The Vinyl windows, properly installed work real well for me on my 100+ year old house. Of course, I insulated all the walls and also installed vinyl insulated french doors going out to my patio. One of the correspondants warned you about stacking them outside and waiting too long to install, he's right, you run the risk of the seal failing and they will CLOUD OVER !! Fringe benefit is the house is way quieter now than it used to be'!! Best of luck ! JimB.
glennster
11-08-2007 18:58:46
new insulated windows will make a big difference in your heat bills. last year i put pella's and a jeldwen at the mil's house, cut her gas usage close to 30 % i am in the process of replaceing the windows at the body shop, it had old single pane units , with about half the building replaced, i can already notice a big difference. stick with a name brand that has been around a long time. pella, jeldwen and anderson are a few good brands.
Charles (in GA)
11-08-2007 18:50:11
A friend of mine lives in a 1900 vintage country farm home. Its cold and somewhat drafty, and is only heated with a fireplace insert and three freestanding propane heaters. The windows were the tall ones, real loose fitting and had counterweights. The replacements fit into the original frames, they just took the sashes out, the new ones, each was measured for exact dimensions and squareness, was fitted and sealed in place. They look real nice and it made a huge difference in the inside temps and how much heat is retained.
Charles
suptscottyb
11-08-2007 17:32:23
When it comes to holding heat in a house windows ARE an important place to look for loss. You do loose more through a poorly constructed window than a poorly insulated wall. Especially if that wall has wood siding which is. Correct me if I'm too wrong but, 1 inch of wood is equivalent to R12+-. Vinyl windows do have problems when exposed to alot of sunlight. Do not stack them in the sun and wait weeks to install. They will wilt and not shut right afterwards. But the vinyl is not going to transfer cold/heat like aluminum frames do. Like Billy said proper instalation is everything. Modern windows can help an old house hold heat.
Stan in Oly, WA
11-08-2007 19:00:10
 Re: New windows in reply to suptscottyb, 11-08-2007 17:32:23
Hi suptscottyb,
"Correct me if I'm too wrong but, 1 inch of wood is equivalent to R12+-." Wood that it were true (sorry, that was bad.) You misplaced the decimal, unfortunately. Softwoods and plywood have an R-value of 1.25 per inch, hardwoods .91 per inch. Sawdust is R 2.5 per inch and I used to find it occasionally in the exterior walls of old houses in Seattle I would buy to renovate and resell. More commonly, houses built before 1950 had no insulation in the walls, and black rock wool amounting to maybe R-8 in the attic. I can't figure out whether people then wasted heating fuel because it was cheap, or they just didn't expect the whole house to be toasty warm all the time.
All the best, Stan
suptscottyb
11-09-2007 05:37:13
 Re: New windows in reply to Stan in Oly, WA, 11-08-2007 19:00:10
Stan, thanks for the correction. It had been about 25 yrs. since I had heard the statistic. Old houses were built on old techknowledgy, like the cars of that era. Sawdust has a higher R value because of the air trapped in between the wood particles. However it tends to rot. I've seen newspapers used in houses. Makes for very good reading when remodeling!
Ohio88
11-08-2007 17:13:38
Had Vinyl installed about 10+ years ago. No problems so far. We replaced 30+ year old Aluminum which did have some seal leaking the last 5 or 6 years so there was some cloudiness. The bigger problem with aluminum was the air leaks and the resulting water accumulation. So far none of that with the vinyl windows. We looked in to wood and came to the conclusion that all of these windows have problems after time.
Billy NY
11-08-2007 14:55:26
I can't imagine how many manufacturers of windows there are for residential buildings, and the asscociated product lines available, but if it were me, I'd pay close attention to the performance data available for the line they're pushing.
Air and water infiltration are about the 2 most important other performance aspects, besides the thermal performance. Check the listed performance criteria, I believe that all these manufacturers are subject to getting their products certified by various manufacturers associations or reference standards. I used to work in the metal and glass industry, and we started building exterior doors in our shop, and had to get them certified prior to making the line available. It was quite the process to get that done and get all the bugs out of them. One of the most impressive testing facilties I've ever seen was ATI in York P.A., have done several mock ups there and tested same, very interesting place to walk around.
See what reference standards and or manufacturer association criteria it's been tested to, ask the sales rep. Look at the jamb, head and sill in section, and have the rep. explain to you how the system works, have them explain the entire window system, including the glazing (glass) etc.
That is one half the battle, the rest is the installation, you could get the most expensive top of the line, highest performing window unit and the installer does a poor job installing it in the rough opening. The installation must be quality workmanship as well for it to perform.
If you want to let the air out of the sales people, do some research and have a list of important questions, like mentioned above, as well as all particular details, in section, plan, elevation, fastening, flashing, sealant and sill details, this will give you a good understanding of what they are selling. Also for residential, the window balance system is also important, as well as the operational functions of the window.
I'm sure they don't like construction savvy people asking questions, much rather prefer the deer in the headlights, similar to when people go to an repair shop or dealer for work, too funny when it turns out to be a mechanic and they look foolish.
ed19
11-08-2007 14:36:50
Can't really see how new windows will help if the walls are lacking in insulation. My problem would be that the windows are the least of my problems since i have an old house that probably new insulation more than windows. Not an answer to your question just a thought.
Sid
11-08-2007 20:52:17
 Re: New windows in reply to ed19, 11-08-2007 14:36:50
"Can't really see how new windows will help if the walls are lacking in insulation. My problem would be that the windows are the least of my problems since i have an old house that probably new insulation more than windows." Here is something to think about. I do not know what size windows you are talking about but I have several double hung windows in my old house that are about 30 inches wide and 72 inches tall. That gives me a crack about 234 inches long of least 1/16 of an inch wide. Consider that a 1/16 of an inch crack 16 inches long is equal to a hole of one square inch. One window equals a 14.6 square inch hole in the wall. Not to consider the heat loss through a single pane glass.
Sid
11-08-2007 20:51:24
Old Magnet
11-08-2007 16:55:14
Those double pane windows are a real pain. After so many years (about 10 to 15) the seal leaks and they draw moisture between the glass which eventually turns the window opaque....and that was the premium aluminum frame units....can't imagine what the vinyl crap will do. Real fun to replace on a stucco sided house. Trouble is none of the companies stay in business long enough to validate a warranty.....ahhhhh made in America. Cause the problem then sell the cure.
Billy NY
11-09-2007 05:37:32
 Re: New windows in reply to Old Magnet, 11-08-2007 16:55:14
Another quality issue, there is some real technical jargon for glazing in ASTM and so on, anytime you are looking at windows, always take notice of the glazing manufacturer, you can do some research to see what you are getting with that window. Probably best to stay with an established glazing manufacturer, like Viracon or similar. Not sure how many of these window manufacturers use products from companies like this, but I'd trust them to perform, more than any others. Insulated glass will perform, just need a qualuity manufacturer.
