Tool Talk Discussion Forum
Broaching an inside keyway
GIJ
11-06-2007 04:20:44
Hi All. I need to cut the inside of a 7/8 pulley bore for a 3/16 key. I understand this is done with a broach. Where's a good place to get one and the shims/bushings that go with it? And maybe even read up on the process? Thank you very much.
landlord7012
11-06-2007 18:54:26
 Re: Broaching an inside keyway in reply to GIJ, 11-06-2007 04:20:44
Where are you at? I've got an attachment on Bridgeport for broaching and assorted tools for it.
ll
GIJ
11-07-2007 16:04:55
 Re: Broaching an inside keyway in reply to landlord7012, 11-06-2007 18:54:26
NE PA. Far? So far my search for a shop with the right tools turned up zilch. Everyone seems to contact out this type of work.
landlord7012
11-07-2007 16:21:59
 Re: Broaching an inside keyway in reply to GIJ, 11-07-2007 16:04:55
The shipping would probably cost more than anything. Check out UPS shipping to/from 54220 (you would probably want a little insurance as well. I could probably do it for "a case of beer". Only thing is how long is the keyway (please give all dimensions again). I astounded you don't have anything close, probably a sign of the times. "Creative machinists" are disappearing rapidly. Truth is with the right tooling and the quill of a manual mill you can do some basic shaping and broaching.
ll
ll
Spook
11-06-2007 12:41:09
I would call around to local machine shops.
Midwest redneck
11-06-2007 12:32:38
You need to take that to a machine shop, It would take about an hour to do it with a broach set and an arbor press, the broaches cost too much to buy for a one time deal. A broach set is about $350 and the one broach you need is about $25 or so, not including the bushing.
Gerald J.
11-06-2007 08:02:15
You could start it with a hack saw blade and finish it with a square file or a mill file on edge. Might take a few tries to get it parallel to the bore.
You could cut it with a cape chisel.
You could cut it with a lathe, drill press, or milling machine. There without anything turning, you make a properly shaped tool to cut while moving into the bore, and you shave it a thousandth or two per stroke of the tool post, or the quill. There have been lever operated gadgets made to do the sliding on a lathe to save cranking the apron left and right.
Paying the pitance to have it done with a broach in a shop that already paid for the broach 40 years ago is often most profitable.
Gerald J.
Chris(WA)
11-06-2007 06:55:05
Grizzly has a good inexpensive set of broaches.
TomTex
11-06-2007 05:26:39
Can't imagine buying a broach, when the machine shop in Fort Worth will cut any standard size for you shile you wait at the counter for a flat $10. Tom
Vern-MI
11-06-2007 04:57:36
Kinda pricey but you can do it if you have the associated equipment to pull them. Each tooth cuts a little deeper than the last. We found sending that work out was much more cost efficient.
IaGary
11-06-2007 04:51:53
What are you going to push the broach with?
For one keyway I would go to a machine shop and let them do it.
You may never use that expensive broach again.
Gary
