Tool Talk Discussion Forum
Cement on a spade-removal
DCM
11-05-2007 15:24:33
Any good ideas for cleaning the hard cement residue off a spade after hammering off the main chunks.Dan
john *.?-!.* cub owner
11-06-2007 19:15:08
 Re: Cement on a spade-removal in reply to Chris Vangel, 11-05-2007 15:24:33
I would think a needle scaler would work, plus they have a lot of other uses after you buy it.
Link
Pete in MD
11-05-2007 21:10:48
 Re: Cement on a spade-removal in reply to DCM, 11-05-2007 15:24:33
Muriatic acid will clean it off. Get a gallon at the hardware store for about $5.00.
matthies
11-05-2007 18:25:21
I was thinking vinegar, but never tried it. chris
MF294-4
11-05-2007 16:38:26
I have a barrel of acid that we use on the mixer trucks. That will clean it up.
Stan in Oly, WA
11-05-2007 16:26:08
Hi Dan,
If you're talking about getting it back into good shape like you might do before you put it away for the winter, or just because it's gotten away from you, you can clean hard concrete off a steel surface pretty quickly with a wire wheel on an angle grinder. Knotted wire wheels work best.
Safety reminder: blah, blah, blah, blah, your eyes, your ears, blah, blah, blah, breathing dust, blah, blah.
All the best, Stan
Bob
11-05-2007 16:12:45
Shovel a couple of "yards" of gravel with it!
Grizz
11-05-2007 16:16:23
 Re: Cement on a spade-removal in reply to Bob, 11-05-2007 16:12:45
I usually just smack em on a rock and they are good to go.
DCM
11-06-2007 06:11:33
 Re: Cement on a spade-removal in reply to Grizz, 11-05-2007 16:16:23
Thanks for your suggetions but I will only take Bob"s as a last resort. Dan-Alberta
