Tool Talk Discussion Forum
miller bobcat propane powered welder
j105
11-03-2007 19:17:26
IVe got a bobcat 225 that runs good, welds good has about 570 hours on it. It has an Onan engine that runs on propane. the problem i am having is starting it the first time each day. i have to remove the air cleaner and cover the intake momentarily with my hand (choke) to get it started. then after that it will start fine the rest of the day, unless it sits quite a few hours between starts. this is the only propane engine ive ever been around. any ideas are appreciated. j
Garry in OK
11-03-2007 21:53:13
 Re: miller bobcat propane powered welder in reply to j105, 11-03-2007 19:17:26
I have a 225 on propane. It has a Beam regulator which has to "sense" a slight vacuum or the fuel won't flow. Don't know if other types are like that or not. It starts easier when choked for a couple of seconds, even if it's hot.
I believe in this application the choke isn't altering the fuel/air mix, it's creating the necessary vacuum to allow fuel flow.
I've tried to read and understand the manufacturer's "how it works" write-up, but just wind up with a headache and another entry on my steadily growing "Things I Can't Figure Out" list.
j105
11-04-2007 16:14:51
 Re: miller bobcat propane powered welder in reply to Garry in OK, 11-03-2007 21:53:13
thanks for the reply garry. my list is getting longer and longer. wish i was just half as smart as i use to be when i was a teenager.
