Tool Talk Discussion Forum
Welding helmet
Goose
11-02-2007 10:05:46
I broke down yesterday and sprung for an automatic darkening helmet for my Mig and arc welders. I do a quite a bit of auto body work and use the Mig for a lot of spot and plug welds.
Maybe I'm a "Johnny-come-lately" and all the rest of ya'll already have them, but it sure turned welding into a whole new ball game.
RobMD
11-02-2007 20:01:49
 Re: Welding helmet in reply to Goose, 11-02-2007 10:05:46
a standard, NO SENSITIVITY ADJUSTMENT auto-darkening helmet is NOT RECOMMENDED FOR USE WITH LOW-AMPERAGE WELDING. I know from experience as I was trying to weld some 20 gauge sheetmetal, and it did NOT change over. You will need the sensitivity adjustment. This will cost you 250 bucks for a loaded helmet.
Stan in Oly, WA
11-02-2007 19:31:09
Hi again, Goose,
Here's my take on the strong feelings people have about any products where a choice is involved. Most people consider themselves to be fair minded and reasonable. When required to select a particular product from a number of choices, they believe they are capable of using objective criteria to decide. My experience leads me to believe that this is rarely true. People develop strong opinions about all kinds of things and then have the very normal tendency to give great weight to evidence that supports what they believe, and find persuasive reasons to discount contrary evidence. This is why so-called anecdotal evidence carries little weight in scientific investigation.
My attempt to test auto-darkening welding helmets was necessarily compromised by my inability to devise a way to conceal the brands from myself, and because I have no way to measure or factor out my own prejudices. The only time I felt that I made a totally objective observation was for just a moment when I forgot which helmet I was wearing. I thought I was using the instructor's helmet with the oversized viewing area, and I remember thinking that visibility seemed very good. When I discovered that I was actually using my own (Harbor Freight) helmet with the standard sized viewing area, I thought it was fair to conclude that the oversized viewing area just didn't make much difference to me.
About the cumulative effect of the 1/25,000 of a second flash each time you strike an arc, I just can't say. I'm blessed with excellent vision (I'm 61 and I still don't wear glasses) and my eyes are not sensitive. I've spent most of my life not wearing sunglasses in bright sunlight, which I only recently learned is not supposed to be good for you. When I was first learning to weld I used a standard helmet, and flashed myself at least a dozen times per practice session (forgetfulness + tiredness + slow learner) and I never experienced the telltale sandy eyed feeling of flash burn. What I'm trying to say is that my experience with the accumulated flashes of an A/D helmet may not have anything to do with what someone else encounters. Just because it has never bothered me doesn't mean it might not bother you.
All the best, Stan
Phil Crome
11-03-2007 19:03:35
 Re: Welding helmet in reply to Stan in Oly, WA, 11-02-2007 19:31:09
Stan,
I really appreciate the straightforward way you approach your posts on this board. It's refreshing to see someone who actually has a thought and can express it. This board is fortunate to have several folks who do just that.
Re: autodarkening helmets and arc flash- it is my understanding that ALL of the AD helmets made by the reputable manufacturers - Speedglas(own 2), Miller (own 1), Hobart, etc.- are 100% UV safe regardless of lens state, just like the vast majority of quality safety glasses, thereby rendering them no more or less likely than any glass shade of similar darkness to flash you. I have used an AD helmet for 15 years through periods of heav fabrication welding down to sporadic use in farm welding with never a problem.
Interesting observation about anecdotal evidence. Anecdotally speaking, the only AD helmet user I have ever known who claimed a flash was a guy who shared a bay with me in a truck body manufacturing plant who, despite his AD helmet, persisted in both tacking behind a glove with his hood up and refusing to wear glasses. Of course, his flash was the fault of his helmet.
Regards,
Phil Crome
Stan in Oly, WA
11-04-2007 13:24:19
 Re: Welding helmet in reply to Phil Crome, 11-03-2007 19:03:35
Hi Phil,
Thanks for the words of encouragement. I'm definitely not to everyone's taste, though. A few years ago I saw a quote saying that we're prouder of the strength of our beliefs than the clarity of our thinking. I can't remember whether it was stated in regard to Americans or to our whole species. Either way, I find it both true and enormously depressing.
I'm glad you brought up the point that even in their clear state, A/D helmets block 100% of UV light rays. I suspect that this makes the occurrence of flash burn considerably more subjective in nature than most A/D helmet detractors would care to admit. But, you often get what you expect---sort of a reverse placebo effect in this case.
All the best, Stan
soundguy
11-03-2007 23:10:55
I have a HF AD helmet, and a generic TSC flip up style.
I can't get used tot he AD helmet.. As I see the initial spark.. but not a flash..
I do see that the package says that the filter blocks 100% uv whether darkened or not.. guess that's a good thing.. etc. So far.. I've been using the flip down.. it's what I'm used to..
Besides.. with stick welding.. i can usually see where I'm out when i scratch-strike the arc..
soundguy
rockyhawaii
11-02-2007 17:55:19
I had the $50 HF battery-operated helmet and it quit after a couple of uses. I replaced it with a solar-powered Lincoln brand (don't know who makes it) and it's been working fine.
Bob Smith
11-02-2007 13:23:05
I have a Hobart auto-darking helmet and like it very much, My only complaint is that I cant get a Cheater lens in it, For you young guys a cheater lens is a magnification lens, Kind of like reading glasses.
I have been welding for over 30 years as a maintenance man in a Steel Mill and just recently bought my first AD Helmet due in part to the fact that the older I get the harder it is to see while welding, I do mostly general welding and fabrication no pressure piping or vessel welding but recently had a conversation with a pipe fitter that dose nothing but that type of welding and found that they don't use AD helmets because they believe that over the course of the years the minute flash you get from an AD Helmet is damaging to your eyes? And this was not just one welder but everyone in his local. I don't know but I guess it could be possable if you welded everyday for 30 plus years?
But for me I weld maybe 5 or 6 times a week I'm sticking with the AD Helmet myself!
chvet73
11-02-2007 12:56:34
I love mine it is mid priced one. But I had a HF before it and it worked fine too. Then after about a year it's view area kept get more and more didcoloration until it stopped working altogether. When it worked the HF was a good product but it did not last. The one I have now has worked fine for several years. And I prefer it over a regular type.
Harvesterguy
11-02-2007 12:47:50
I have had 2 different auto-darkening lenses, both of which were more than $175, and don't use either one anymore. I've gotten welding flash twice from auto-darkening helmets and don't intend for it to happen again. I've found that I couldn't do any better job than with a standard lens, but, most of my welding is MIG. If I were doing a lot of TIG, requiring me to have both hands, I would probably pick the auto's back up. Several professional welder friends of mine have told me they have taught themselves to blink just as the arc is struck to avoid the flash, but I never seemed to be coordinated enough to do it.
-Harvesterguy
ohio
11-02-2007 13:58:48
 Re: Welding helmet in reply to Harvesterguy, 11-02-2007 12:47:50
I've had a jackson for about ten years, my brother has one of the first jackson eqc's for twenty maybe, no problems to date. I Used to do mostly tig build up & hard surfacing on tool steel, now mostly structural work with a mig.
Stan in Oly, WA
11-02-2007 11:35:07
Hi Goose,
This is one of those subjects that really polarizes people. Some people are adamant in their belief that the cheap helmets fall somewhere between inadequate and worthless, some people find them perfectly adequate. I've had experience with several varieties of cheap helmets. Some of them didn't work as well as they should have---but only in non-critical areas like slow recovery time, the return to clear state from dark. That's annoying, but your eyes won't be harmed by it.
I have found Harbor Freight's brand, Chicago Electric, to work just fine. The head of the welding program at the community college where I spend a lot of time hates all things Harbor Freight. He claims HF auto-darkening helmets are crap. Recently I decided to test helmets side by side under exactly the same conditions. I switched back and forth between my beat up HF helmet, and the boss's Speedglass (certainly one of the best brands available.) On two other occasions I did the same thing with another instructor's different model Speedglass helmet, and with a student's top rated helmet (don't remember that brand, though.) My conclusion was that the other helmets, at 5 to 6 times the cost of a $50 (on sale) HF helmet, had some features which were better, for sure, but none of them were better across the board. For instance, the instructor's Speedglass had a larger window, which I thought made much less difference than I expected it would. The clear state on that helmet was slightly lighter than the clear state of my helmet, which I felt was valuable, and the helmet's face plate was hinged so that the darkening unit could be swung up out of the way for grinding. I had very mixed feelings about this feature because I know that I would eventually duck under something not far enough and rip it off the helmet. I would consider it a good feature if I did my welding the same way in the same place every day, as in a production setting. But I'm hard on helmets as it is, and something sticking up an additional four inches just wouldn't be safe with me.
I thought that the darkening speed, the recovery speed, and the darkening level of the HF helmet were all comparable with the expensive brands. So, for what it's worth, I'll probably stick with HF, maybe buy one helmet of a reputable brand just to wear when royalty visits.
All the best, Stan
Puddles
11-02-2007 12:29:41
 Re: Welding helmet in reply to Stan in Oly, WA, 11-02-2007 11:35:07
Sometimes it�s just hard to beat old school!
http://www.photolava.com/view/8xqg.html
Puddles
11-02-2007 12:34:33
 Re: Welding helmet in reply to Puddles, 11-02-2007 12:29:41
Try this again
Goose
11-02-2007 11:04:03
Specs say it darkens in 1/25,000 of a second, and the level of darkness is adjustable. With the setting for Mig, I felt comfortable with the darkness level.
JT
11-02-2007 11:18:33
 Re: Welding helmet in reply to Goose, 11-02-2007 11:04:03
Sounds like you got a decent one, you will love it.
JT
11-02-2007 10:26:43
As long as you got a good one, you will like it, some of the cheaper ones do not have dark enough lenses in them and the auto darkening feature is a little slow, so it can still burn your eyes, but I would not give up mine for nothing.
Gary From Muleshoe
11-02-2007 10:13:18
I am just an armature welder, but I do like mine. I put it off for a long time, until a friend of mine that welds for a living got one, he raved about it. I figure if the pros like them then why not. Got mine at HF for $50.00, works great.
