Tool Talk Discussion Forum
T-Post Jack?
hayray
11-01-2007 16:15:47
Wondering if those T-post jacks work well? If you have a whole bunch to pull out are they faster and easier than using a chain and a front end loader. Are the ones TSC sells good enough?
Thanks in advance, Ray
Pooh Bear
11-04-2007 03:53:47
 Re: T-Post Jack? in reply to hayray, 11-01-2007 16:15:47
I got one on sale from Harbor Freight for $17 plus %15 off coupon.
Pulled one post that I thought would be too hard and it came out just fine.
Pulled a second post that I just knew it wouldn't come out and it did.
Tried to pull a third post that I thought would be easy and the T post lifter broke.
Harbor Freight exchanged it for me.
I plan on strengthing up the new one before I start pulling posts again.
For pulling posts in soft ground they can't be beat.
I got a lot of T posts down in the garden for tomato stakes.
Should be able to pull them real easy.
The pullers from Harbor Freight, Tractor Supply, and Northern Tool,
are all the exact same puller as far as I can tell.
Pooh Bear
PJH
11-02-2007 10:05:51
Forget about the loader and store bought jacks - Turn your post driver upside down and set it on the ground a few inches from the nub side of the T post. Push the post away so the edge of the driver catches under one of the nubs. Now pull the post back toward the driver and as you pull, it will lift the post out of the ground. Work the post back and forth and the nubs will work like a ratchet on the edge of the driver. About three pulls is usually all it takes to have it out of the ground. Works best if the ground is dry so the driver won't push into the ground. You can lay a 12" piece of 2X4 down for a bigger "footprint" if the ground is soft. I pulled and loaded 100 posts after work one evening by myself. They were gonna by dozed out the next morning, and the foreman said I could have whatever I got that evening.
Nolan
11-02-2007 04:38:24
Yes!
I used to use chain and a bumper jack. It worked, but certainly wasn't fast. Those cheape t-post jacks do the job lickety split.
msb
11-01-2007 19:54:31
Fastest way: Loop a chain around the post 2 times. Hold the loose end of the chain and then step on the chain up close to the post. Raise the loader.Give the post a flip with the chain ands it will come loose from the post.Pull them almost as fast as you can walk that way.
John S-B
11-01-2007 19:47:09
If you have a helper to wrap the post with a chain, a loader would be faster. Unless the loader can't get to the posts because of trees or would tear up the ground, I'd go that route.
RichZ
11-01-2007 18:00:58
I have one that I bought from Harbor Freight. It works great. I use it all of the time.
K.W. in Tx
11-01-2007 16:29:48
They work unless you have alot of clay in your soil like me. I built me a special post puller that works like a driver except it does the opposite.
