Tool Talk Discussion Forum
Rusty and smelly well water
Bob in Oakboro
11-01-2007 14:22:16
I have recently moved NC. The water has an odor not quite as bad as rotten eggs and is turning everything a rusty shade. Does anyone know a good place to start in curing this?
buickanddeere
11-02-2007 16:30:43
 Re: Rusty and smelly well water in reply to Bob in Oakboro, 11-01-2007 14:22:16
Is a dug well which supplies spring water possible instead of a drilled well which supplies bed rock water?
Cliff (VA)
11-02-2007 05:17:57
Well you are bringing back memories. We had water with iron deposits so bad that it looked brown coming out of the ground.
We went through a water softener, then switched to a greensand tank with with a potasium permanganite backwash, and finally ended up with a oxygenating system followed by a filter.
The oxygenating system was by far the best, but it used a lot of backflush water and a compressor. Abut 3.5K from Rainsoft.
The water softener with iron salt will work if the concentration is not too bad. This will be your cheapest route. However, when the water is as bad as it was at our place, the softener just gooped up with brown sludge. (I did not buy this but it was a Cooligan).
The greensand/permaganate system did work well, but there were several problems with it. It leaked some small amount of the potasium permanganate into the house water. This meant that we could not use bleach in our laundry and if it was bad the shower made my skin peel. Although it was MUCH better than the softener, in the end it also could not keep up with the iron in the water. About $3K from Rainsoft.
I have moved from the house with the terrible water. My current house has minor iron problems, is slightly hard, and has the sulfer smell. We currently have a oxygenating system followed by a filter tank to get rid of the iron and sulfer. Works great. I am considering adding a softener to get rid of some of the calcium deposits on the dishes. The current system has been no problem and just backflushes with water (no salt or other chemicals).
If the problem is bad, I would suggest getting a couple of professional opinions (usually free, but worth what you pay for it). Just remember that the water treatment companies are there to sell you something.
HTH
Cliff (VA)
PS If you have not discovered "Iron Out" you need to try and find some at Lowes. It will take out iron stains when nothing else will. Unfortunantly it also bleaches some colors and weakens some textiles.
tompepper
11-01-2007 16:09:29
a few years ago i stumbled on to a unit called waterboss.the unit is small and can be put in a confined space{under counter,etc}this thing has given use 10 years of trouble free service.you can use the iron salt in it also.I have talked several people around here into getting the water boss and they all like it.Model #900(whole House)it took stinky water to drinkable water almost instantly.and the pricr is way lower than your softner companys.I got mine at central tractor but tractor supply doesn't handle them.the last unit i helped put in my cuzs house we got from ACE hardware.these units are less than 1k and you don't have thoses big ole bulky tanks taking up space.
ford-s
11-01-2007 15:28:46
bob,whet you are experiencing is hard water,if you let it go long enough it will stain everything.get a GOOD water softener and that will solve your problem.we had the same problem,we paid 1 company 2500.00 to put one in that lasted 6 months then tore up.so we went to 'CULLIGAN',it's been 6-7 years no trouble yet,that is a good co. CW
JJ. in B.C.
11-01-2007 15:23:35
You got Iron and Sulpher in your water, we fixed the problem with a combined water softener/Iron remover, this will take out all the "rust" an' most of the smell, ya can go on from there with any number of filters either whole house or under sink versions
Russ from MN
11-01-2007 15:22:45
We have a similar problem at our cabin and a filter with a softener downstream solved it. I use the rust remover salt and it has worked good for 5+ years.
bjb in Ne
11-01-2007 15:19:10
First what type of pipes (iron, copper, pvc) do you have. Second has the well water been tested. Sounds like you have a large concentration of iron in your water. Could be from either the pipes if they are iron or the water itself, or a combination of both. The rotten egg smell is from some sulfur compound, that may be in the water or from some contamination source, like your leech field. If you have not tested your water you should. Your local extension agent should have cheap unbiased sources for having your water tested.
