Tool Talk Discussion Forum
Tire bead breaker
MF Poor
10-29-2007 10:44:06
For some odd reason, the hammer and tire irons that have served me well until my 60th birthday whipped the daylights out of me over the weekend. 2 tractor tires that have been mounted for almost 25 years just about beat the old man. In a fit of desperation, I borrowed a bead breaker from a friend. It was meant for truck tires. While using it, I broke a weld. I get to buy him one and me one now. (I"ve got another 2 tractors needing rubber soon)
Any suggestions? Cheap is good, but I realize that a GOOD one will cost a few bucks. I could use air powered, hydraulic, or even a good manual powered one. Who makes "em? Who sells "em? How much?
44 massey
11-02-2007 15:30:18
 Re: Tire bead breaker in reply to MF Poor, 10-29-2007 10:44:06
I have a 450 farmall with 2pt fast hitch which has down pressure and a rear 2pt blade. Just set the blade right of the tire bead and lower, course I realize not everone has an IHC with fast hitch just stating what works for me!!
markct
11-02-2007 15:17:13
well i have found an old dull pickaxe ground smooth to work well, but for the real stuborn ones i had to change on my roadgrader the backhoe did the trick, just pushed hard with a tooth in a couple places and finaly they broke free
PJH
10-31-2007 08:12:27
Do you have access to a vertical log splitter?
mlauk
10-30-2007 10:28:22
Sloan Express has a Bead Cheata for $139. Works great. It is similar to the one at Gemplers.
cat236
10-30-2007 02:19:42
I have a young man who I kinda mentor ,teaching him mechanics and in exchange he helps out around the house. He does quite a lot of scrap and had several aluminum rims with tires. He hooked up the 16' trailer and used the trailer jack and weight to break the beads, my slide hammer breaker wouldnt break them.Worked very well other then the cranking of the jack handle,not hard just time consuming.good luck
glennster
10-30-2007 07:01:39
 Re: Tire bead breaker in reply to cat236, 10-30-2007 02:19:42
dang that trailer jack is a good idea!!! maybe make a braket to slide in the receiver hitch on a truck, back up to the tire and crank the jack down, or, make a bracket to mount to the drawbar on a tractor..... . now you got me thinking.....
K.W. in Tx
10-29-2007 20:46:03
I made a thing out of heavy steel thats long,flat, and has another flat piece at a slight angle welded on the end with a bevel on the end of it. Then I lay it on the bead next to the rim and the other end lays on the ground and then I take a vehicle and drive up on it and it breaks the bead. Waaala!
Maark
10-29-2007 19:44:00
If you're not saving the tire, cut it off with a sawsall. Takes just a few minutes.
jokers
10-29-2007 19:13:01
I think mine is a Kentool, it`s the type that is a large slidehammer. It works very well. Gemplers had `em, probably still do.
Robert Searcy
10-29-2007 18:55:47
Here are a couple tricks i use, drive your truck or tractor up on the edge of it and it will sometimes pull them down off the rim, also i use the loader of my bobcat or tractor, put the edge of the bucket right up against the rim and push down, this works great as well
old
10-29-2007 18:49:51
Soap and lots more soap. Let it sit over night with a good bit of soap on them and then hammer them some more and add more soap. I have run into the same problem many times but so so none have got the better of me but it does take a lot of soap and a good bit with the hammer. I have an air powered one that I need to fix but so far the hammer works just as good so why work on the air one, maybe when one gets the better of me I will
glennster
10-29-2007 11:27:27
gemplers dot com has a manual tire bead breaker that mounts on the rim, they are about 169.00. it clamps on and you tighten a bolt and it pops the bead loose.
JoeK(WI)
10-29-2007 13:43:49
 Re: Tire bead breaker in reply to glennster, 10-29-2007 11:27:27
I quit doin anything bigger than car tires awhile back.Just wasn't worth the savings vs the beatings.However I did find on them long time rusty ones,soaking the crack overnight w/PB blaster can really help.
