Tool Talk Discussion Forum
forming an 8-inch diameter collar from sheet metal
Tim B from MA
10-26-2007 11:55:07
I have a great old "Easy Rake" brand (bought by Bluebird) leaf sucking trailer that you tow with a lawn mower. The blower intake (vacum) was made to accept 6-inch diameter hose. I upgraded to a mower with a deck boot that uses 8-inch. I need to make a new flange for the blower that has a 3 to 4-inch deep collar to accept the 8-inch hose.
I don't own or have ready access to a slip rolls, so ....
So far my only idea is to use a 3 or 4 inch wide strip of 16 ga sheet metal and wrap it around an 8-inch disc (or discs) of ply wood using clamps, heat, and elbow grease.
Any other ideas would be greatly apprieciated.
Tim B from MA
10-26-2007 14:08:51
 Re: forming an 8-inch diameter collar from sheet metal in reply to Tim B from MA, 10-26-2007 11:55:07
I got the new (used) mower last year, and have been using a 6"-8" stove pipe reducer (stepped down, not tappered) along with a short section of pipe (to gain some length), and it causes a lot more clogging than I had with the straight 6-inch set up.
I need longer hose anyhow, since I'll be spending that $$$ I want to make it all more durable and work better.
Sid
10-26-2007 18:50:11
 Re: forming an 8-inch diameter collar from sheet metal in reply to Tim B from MA, 10-26-2007 14:08:51
Seems to me you need to reduce at the deck and go back to a six inch hose.
T_Bone
10-26-2007 15:31:47
Hi Tim,
As Nathanial stated, 16ga is very easy to hand form. The best looking hand made "collar" is made by rolling over a piece of pipe (a lite pole is handy). Always under roll (larger diameter, 10" or so) light gauge metal as it forms best.
Roll more than what's required for the circle as the first couple inchs will be flat, even if using slip/power rolls. Another trick is to weld the joint then round form the 2" with a wooden/deadblow hammer over a smaller diameter pipe as not too waste material.
On a slip over joint, make the collar 7-7/8" OD. With a collar lenght of 3" there won't be but very little joint leakage at this diameter and almost no leakage if the over pipe bottoms on the flat deck.
Subtract the thickness of the collar metal when figuring S.O. (stretch out or cut length) for a OD collar.
A good rule of thumb is to attach/weld the collar to a piece of square/round plate then weld the square/plate collar to the deck. Skip welding, 1 on 3, should be enough. Do NOT join the oposing welds on a 90� cornner as this will cause the deck to crack at that point as it introduces stress on the flat deck metal.
T_Bone
T_Bone
10-26-2007 15:36:41
 Re: forming an 8-inch diameter collar from sheet metal in reply to T_Bone, 10-26-2007 15:31:47
BTW Tim, you lost 40% of your vaccum when you added the reducing cone and is why your plugging up.
T_Bone
Stan in Oly, WA
10-26-2007 12:53:14
Hi Tim,
Three days ago I bought a 7" to 4" sheet metal reducer at Home Depot for $6.13. It's nicely tapered too. What you're looking for should be in that same price range, I would think. Or maybe, per your information about the cost of house wire, you could get it even cheaper at a sheet metal supply place.
All the best, Stan
old
10-26-2007 12:39:16
They make an 8 inch to 6 inch adaptor for wood stoves and that should work just fine and not cost all that much either.
nballen
10-26-2007 12:13:57
Local HVAC shop may have something like that in stock. 8" duct 'nozzle'.
Or, circumference = pi*d = 25.12"
Cut the strip a couple-three inches longer, also cut tabs every couple inches along one edge - the tab should be "trapezoid" shaped, with the small edge out.
16 ga (or thinner) won't be too hard to bend on an 8" diameter.
Nathaniel
JoeK(WI)
10-26-2007 17:21:09
 Re: forming an 8-inch diameter collar from sheet metal in reply to nballen, 10-26-2007 12:13:57
Go take a leisurly walk through the plumbing and stove pipe sections of a large hardware.There are PVC,chimney/duct pipe and even tapered rubber adapter sleeves that will do the job.
