Tool Talk Discussion Forum
Tubular skylights
Stan in Oly, WA
10-23-2007 23:41:51
I'm installing 4 tubular skylights. They are ODL brand. I started with the one I thought might be the easiest because it was low on the roof and I could reach the ceiling through the hole in the roof. As it turns out, that is going to make it the most difficult of the 4. What I didn't foresee is that part of the installation has to be done from in the attic. I can barely manage to get to that area if I stretch out full length, but that is going to make it almost impossible to manipulate the two sections of 14" duct (both sections have to be angled), cut them to length in place, and tape them together. I break into a sweat just thinking about it.
I'll know a lot more about what can and can't be done after I install the others, but I wouldn't mind having some pointers from anyone who has worked with these.
Thanks, Stan
Stan in Oly, WA
10-25-2007 09:47:17
 Re: Tubular skylights in reply to Stan in Oly, WA, 10-23-2007 23:41:51
Jim or Kent,
Can you do all or most of the installation from the roof, or from the room, or both with two people? It's having to do part of it from in the attic that's going to fall somewhere between very difficult and impossible. The hole in the roof and the one in the room don't line up by about two feet. Access in the attic is terrible. I have to go around the corner of the chimney where I have about 30" clearance from the wall of an attic room. At that same point is furnace ducting about 16" high, and the rafter to ceiling joist measurement is about four feet. The hole between the ceiling joists is about 6' further on, in the direction the roof is falling at about 45 degrees.
I think that to work there at all I'm going to have to put plywood over the joists to lie on, except that first I'll have to tack sleepers to the tops of the joists so that the plywood won't damage the copper plumbing pipes that criss-cross the area. I can't say I've never had a worse location to work in, but I used to be younger. That's why I'd love to hear that it can be done from either or both ends.
All the best, Stan
Stan in Oly, WA
10-25-2007 12:25:22
 Re: Tubular skylights in reply to Stan in Oly, WA, 10-25-2007 09:47:17
Hi guys,
Don't bother to reply. It finally dawned on me that I could get that information from the manufacturer. Long story short---you have to do part of it from in the attic.
Thanks for your previous input.
All the best, Stan
T_Bone
10-25-2007 19:00:50
 Re: Tubular skylights in reply to Stan in Oly, WA, 10-25-2007 12:25:22
Hi Stan,
I've never saw a residential sky-lite that needed any atiic work to install. I'm currious now as to why attic access would be necessary? Any pics?
T_Bone
Stan in Oly, WA
10-26-2007 07:42:09
 Re: Tubular skylights in reply to T_Bone, 10-25-2007 19:00:50
Hi T_Bone,
I'll try to explain it in words---because I'm somewhat computer challenged, not because I don't think a picture would be more direct. The normal installation involves two flanged tubes. The flanges fit into gasketed trim ring assemblies at the ceiling and at the roof. In the attic, the straight end of at least one of the tubes has to be cut to length to allow a 1" insertion into the other. Then the joint is supposed to be duct taped.
The flanges prevent you from putting the tubes together first and then inserting the completed assembly from above or below. Aside from the problem of the flanges, insertion of an assembled unit would be difficult in anything except a straight line. The tubes are segmented like those sheet metal round duct fittings that can be turned to any angle between straight and 90 degrees, except the skylight tubes have 3 sections rather than 4. The skylight where I have so little attic access is the only one where both tubes have to be angled.
I thought about bending the flange straight on one of the tubes so that they could be installed through the roof, then the flange turned out again. The trouble with that is that I'm an indifferent sheet metal worker at best, and having to work right against the ceiling with the trim ring taking up some of the space would be unlikely to turn out well. Since the flange appears to need to be compressed against a gasket, a less than perfect job would probably result in moisture entering the skylight from the living space.
I'm guessing that you'll be able to make sense of this because you're good at verbal explanations, and because of your background in this area. Generally my explanations simply confuse people, even when I know what I'm talking about. Let me know if I haven't explained this well and I'll try to find a way to include a picture.
All the best, Stan
T_Bone
10-26-2007 16:08:04
 Re: Tubular skylights in reply to Stan in Oly, WA, 10-26-2007 07:42:09
Hi Stan,
What I would normaly do is cut a middle section to the correct length, intall the elbows and top flange section, tape the ouside of the joints then drop the completted duck down thru the roof.
To get the correct angles and true cut lengths, layout the install on a piece of metal/cardboard/dry wall/plywood as then it's easy for your mind to see what's needed.
When laying out the lines, always use center line measurements as there's less room for errors with this method when using round duct.
I would then install the ceiling flange, excess duct cut off 1" above the ceiling flange, to the duct work by crimping the 1" so it slips inside. You can buy hand pipe crimpers for around $10.
Too keep the 90's from turning while installing the completed duct, tape the outside of the elbow gores. Be sure to first draw line up marks on the outside of each gore as then you can quickly see if a gore turned while taping.
This method should keep you from being inside the attic and it's easier than it sounds with the drawings you made.
T_Bone
Stan in Oly, WA
10-26-2007 20:44:20
 Re: Tubular skylights in reply to T_Bone, 10-26-2007 16:08:04
Thanks T-Bone, I'll give it a try.
Kent in KC
10-25-2007 08:21:26
We put two in our new house, one in the master bedroom walk-in closet and one in the 'airlock' (foyer). They are nice. The natural light makes it easy to tell blue from black when you're picking out clothes. Ours have a light in them for night use.
Jim in N M
10-24-2007 11:53:37
Hi Stan, I installed ten,3- 14in. and 7-12in. when I built my house, and did all from the inside standing on a ladder,of course I did have to go on the roof to cut the holes up there.I measured from the roof down,cut the tubes to length and pushed them up from the bottom,evan set the angles if needed. I also used 3 of them that I mounted lights into. They sure add a lot of light to the house and you don't have those ugly tunnels in the ceiling. I can't remember the brand,but It was something "Lite"??? HTH Jim in N M
Aaron Ford
10-24-2007 08:40:12
Keep up the commentary, Stan. I will be installing those in my b-room and hallway. Were they expensive?
TIA
Aaron
Stan in Oly, WA
10-24-2007 09:21:17
 Re: Tubular skylights in reply to Aaron Ford, 10-24-2007 08:40:12
Hi Aaron,
The 14" ones were $240, and the 10" one was $160. Two other brands were available at Home Depot; one was a person's name which I can't remember, and the other was Velux. I've installed several Velux flat skylights, both opening and fixed, and I've always been impressed with the high quality. Something about the Velux wouldn't work for us, but I don't remember what it was because we did the price shopping and research more than 6 months ago.
When you make the purchase (if you haven't already) be sure to open the packages before you drive away. One of three I bought yesterday was damaged and had a manufacturing defect, too. Fortunately I discovered it in the parking lot (we had our monthly day of sunshine yesterday or I would probably have opened it in the store) so it only took a few extra minutes to swap it for a good one---or at least one without visible damage.
I'd say the quality of this brand is okay. They're kind of flimsy, but once they're in place they won't be subject to any kind of force other than gravity, and sunlight on the plastic dome. The engineering seems well thought out, and the installation instructions are quite good---like maybe they were written by someone who had actually installed one of them. I felt that they went cheap in one or two places they shouldn't have. The 4 small tabs that hold the trim ring to the plasterboard of the ceiling are plastic---probably good enough, but I wouldn't have minded something more reassuring because the trim ring eventually supports a fair amount of weight.
Today our weather forecast is for sprinkles (one day last week we had sprinkles that caused flooding) so I'll only be working on ceilings and in the attic today. I'll keep you posted if I run into anything it might help you to know about.
All the best, Stan
