Tool Talk Discussion Forum
50 MHz motor
mark
10-23-2007 05:56:24
Will a 50 MHz motor not operate on 60 MHz at all?
What can you do to make a 50MHz motor run on 60MHz?
Thanks.
Gerald J.
10-23-2007 08:08:56
 Re: 50 Hz motor in reply to mark, 10-23-2007 05:56:24
A 50 Hz motor will run 6/5 the nameplate speed on 60 Hz but also may need 6/5 the line voltage. It will also produce 6/5 the shaft horsepower for the same current. No load current may be smaller because at 6/5 the frequency, the core flux will be smaller and so less saturated.
Gerald J.
LM
10-23-2007 06:10:35
 Re: 50 MHz motor in reply to mark, 10-23-2007 05:56:24
I think you mean Hz not MHz. Most 50Hz motors should operate fine on 60Hz it will just run a bit slower.
ebbsspeed
10-23-2007 06:23:43
 Re: 50 MHz motor in reply to LM, 10-23-2007 06:10:35
Actually, a 50Hz motor running on 60Hz power will run faster, not slower.
mark
10-23-2007 06:14:00
Yes, of course Hz. My apologies for waking the dead..hehehe!
Thank you.
Philo Farnsworth
10-23-2007 06:01:32
You got a motor that runs on radio frequencies ??? I'm turning over in my grave !!
