Tool Talk Discussion Forum
Ranger trans
acman
10-21-2007 14:01:52
I have a 1987 Ford Ranger 2.3 4 cyl with automatic. The park works when in reverse it moves forward as does neutral the drive 2 & 1 seems to be fine just happened all at once. Any ideas?
02XLT4X4
10-31-2007 10:26:55
 Re: Ranger trans in reply to acman, 10-21-2007 14:01:52
The trans in my '85 Ranger did the same thing, the fluid was black, smelled burnt and had metal filings in it as well. I pitched the old one and stuck a junkyard tranny in it, 5 years later it still works great. The A4LD tranny isn't the best tranny in the world for reliablity.
BENJAMIN KIMM
10-29-2007 12:10:39
I would also be tempted to check the shift linkage, this happended to my full size ford. Something so simple as a loose ajustment screw can cause this problem. just my $0.02
jeffcat
10-21-2007 16:11:38
The bigger problem if you have a 4x drive. Your transfer case is going bad. I just replaced mine a couple weeks ago. Saw the guy last week and he told me he did FOUR of them is a two and one half week period! I was number one. No body checks the fluid in them. They take ATF fluid. Let us know.
Bob
10-21-2007 14:14:52
Likely, your "forward clutch" has failed, and the plates are burned/warped/torn loose from the splines, or doubled up, so they are dragging all the time.
Ry
10-21-2007 18:11:01
 Re: Ranger trans in reply to Bob, 10-21-2007 14:14:52
Bob is right - your forward clutch has wore out and welded itself together. Bad news for you is the trans has to come apart to fix it.
