Tool Talk Discussion Forum
SA 200 lincoln welder will not arc
Grant Ellis
10-21-2007 14:01:03
This message is a reply to an archived post by arthur neary on May 02, 2005 at 17:41:33.
The original subject was "Re: SA 200 lincoln welder will not arc".
lincoln 200 SA Will Go To High Idle When You Use Grinder But Grinder Just Barely Turns Welder Just Barely Sparks But Will Not Weld High Idle Switch Will Work Any Ideas I Would Sure Appreciate
OneWelder
10-27-2007 17:29:12
 Re: SA 200 Lincoln welder will not arc in reply to Grant Ellis, 10-21-2007 14:01:03
Electric motor rebuild shops sell a stone to dress up commutators- only a couple of bucks
Lincoln will tell you to use one of these- thats how i found out
pa dave
10-21-2007 16:50:04
 Re: SA 200 lincoln welder will not arc in reply to Grant Ellis, 10-21-2007 14:01:03
I have a sa 400, did the same thing, it had sat for a while. another guy said try sanding the armatures with emery cloth and clean the brushes. it did the trick, been working fine every since. hope it works for ya, good luck
Dusty MI
10-21-2007 17:11:41
 Re: SA 200 lincoln welder will not arc in reply to pa dave, 10-21-2007 16:50:04
I was always told not to use emery cloth because it uses metal particals but use fine sand paper which is a non-conductor.
Dusty
RENE'S
10-21-2007 14:31:34
THERE SHOULD BE A SQUARE DIODE BACK BY THE REASTATE THAT EXITES THE GEN. 4 PRONGS CHECK THAT FIRST. MY SAE 600 DID THAT CHEAP FIX. RENE'
