Tool Talk Discussion Forum
wood splitter hydralic pump
ric1
10-21-2007 12:20:44
i built a wood splitter 22 yrs ago i bought the pump from quality farm fleet i let a friend borrow it for about a year now i notice it doesnt have the splitting power it once had sometimes it will just set there on a large piece of wood not even pulling down the engine would it be worth it to take the pump to a hydralic shop and get it checked out or just buy another one i think a new one is $125.00
Midwest redneck
10-21-2007 12:48:37
 Re: wood splitter hydralic pump in reply to ric1, 10-21-2007 12:20:44
If the cylinder extends and retracts and the pump is a gear pump then the relief valve is likely dirty, or the valve has seat is worn. new oil wouldnt hurt either. also check oil level.
Bob
10-21-2007 12:24:33
It could be as simple as the pressure relief in the valve "popping" too soon from wear or a broken spring, or someone tinkering with it, or as serious as a worn-out pump. You and I know $125.00 isn't going to get you very far at a hydraulic shop, so you may as well check into it a bit yourself, starting with the pressure relief valve.
