Tool Talk Discussion Forum
ONAN RV 7000 WATT LPG GENERATOR
SamMI
10-18-2007 15:49:04
New to me item. It is a model 7NHMFA26105G. The unit is LPG fueled. The unit seems to run at 2400RPM, the book calls for 1800RPM. Is this a simple adjustment of the governor? Also; does this unit have an onboard battery charging system? Have been told that some do and some don't.
CH (upstater NY)
10-19-2007 04:00:40
 Re: ONAN RV 7000 WATT LPG GENERATOR in reply to SamMI, 10-18-2007 15:49:04
If it's like my 4kw, yes it has a charger. As for throttle adj, I don't have the service manual here but if this question hasn't been answered by Tuesday, I'll chime back in. I'll quess that you could adjust the governer rod on top (if it goes across the top on your model).
I've got about 1000 hrs. on mine.
Charlie
CH(upstate)
10-19-2007 04:03:49
 Re: ONAN RV 7000 WATT LPG GENERATOR in reply to CH (upstater NY), 10-19-2007 04:00:40
By the way, check the output with a multimeter with a load on it.
