Tool Talk Discussion Forum
How to STOP oxidation
railhead
10-16-2007 19:13:30
How do you stop oxidation FOR GOOD after a battery has leaked on steel??? I have now two pieces that old batteries have leaked on that will NOT stop producing white ox and I have put baking soda, then treated with NO OX Grease (from a phone office) and no stopping. What do you guys use to treat steel that has been exposed to battery acid?
Sunspot
10-17-2007 05:41:33
 Re: How to STOP oxidation in reply to railhead, 10-16-2007 19:13:30
Railhead. Not a direct answer but have you tried the treated pads under your battery clamps? I�ve been using them for a few years and they seem to work for me.
I have the same problem as you on the battery box and the steel hold down clamps. I soaked everything in a baking soda solution and then wire brushed and smeared axle grease all the corroded parts. I�ll let you know how long it lasts as I only did it 4 weeks ago.
Phosphoric acid, LimeAway, CLR, Osphos and Naval Jelly. Will they protect against corrosion or only clean up what�s turning white?
RobMD
10-17-2007 10:17:32
 Re: How to STOP oxidation in reply to Sunspot, 10-17-2007 05:41:33
you have to knock off the white stuff with a screwdriver. NO GRINDING. Then you would put the acid on it, which converts the rust into a oxide. Put around 3 coats on. You would let this dry for 24 hours, then PAINT it. You don't leave the by-product exposed, or it will just rust again.
You can also put undercoating on the surface where the battery lies after you use the acid.
Jim Broughton
10-16-2007 21:00:20
Naval Jelly works well
JD9295
10-21-2007 08:27:01
 Re: How to STOP oxidation in reply to Jim Broughton, 10-16-2007 21:00:20
never thought of that, may have to save up a couple weeks worth though
RobMD
10-16-2007 19:15:29
phosphoric acid.
benny2
10-16-2007 20:15:48
  And That can beRe: How to STOP oxidation in reply to RobMD, 10-16-2007 19:15:29
And That can be found as, LimeAway, CLR in Wal-Mart or Osphos in your local paint store.
