Tool Talk Discussion Forum
Garage Doors
Harvey3
10-13-2007 18:22:27
I have a 7' x 9' Wayne Dalton garage door, it is a model 8300/8500. It has 2 Torsion Springs on the torsion tube (bar). I can't seem to get the tension right. I put tension on both springs and it works ok until the door is raised about halfway, then the top of the door moves to the left and drags against the horizontal track. Are these springs identical ? They look the same to me.
Any thoughts ?
Tks
BobHnwOh
10-14-2007 17:36:55
 Re: Garage Doors in reply to Harvey3, 10-13-2007 18:22:27
Harvey,are your springs wound the right direction??
Harvey3
10-15-2007 13:01:21
 Re: Garage Doors in reply to BobHnwOh, 10-14-2007 17:36:55
Bob I believe the springs are wound correctly.
Having said that, I spoke to a door tech. today, he said that type of door only needs one spring, and that it won't work properly with two springs. Two springs are used with doors 12' or wider. I'll try the one spring. (not sure why I got two springs to start with.) Hopefully that will solve the problem.
Harvey3
10-14-2007 17:21:18
Thanks for the replys on this thread.
This door is level when closed, the hori. and vert. tracks are plumb and level. I have the drum cables tight and I've tried more tension on the left hand spring. Nothing seems to work, it's as if the springs are screwed up. Anyway I'll keep trying.
Harvey
Gerald J.
10-14-2007 15:37:50
Are both cable drum setscrews tightened? Its as if one isn't pulling its share of the load.
Gerald J.
BobHnwOh
10-14-2007 15:10:08
Sounds like your door is not level when it's in the closed position,Bob.
Russ from MN
10-14-2007 04:40:56
When the two springs are on the same shaft they only help each other, they don"t pull independently, like an extension spring. They still need to have similar torque, but I would say you have some binding or you may need to adjust a cable, as I did for my neighbor last week.
S. Crum
10-14-2007 12:16:13
 Re: Garage Doors in reply to Russ from MN, 10-14-2007 04:40:56
That must be why mine was so cheap to buy. Mine has a split shaft (not a common shaft). The springs had a white stripe painted on them and I was told to tighten the springs an even number of wraps (count the number of turns of the stripe.) The right side is 9 and the left 10 to work smooth.
S. Crum
10-13-2007 20:12:18
I had the same problem with a 9"x9" steel overhead door. I just twisted the left spring tighter than the right. The springs may look the same, but I doubt they are matched at the factory to any great degree of precision.
Gary from Muleshoe
10-13-2007 19:20:08
You may need to put a bit more tension on side that is binding.
