Tool Talk Discussion Forum
Drill Doctor
Gary From Mules
10-11-2007 14:05:35
I have been thinking about getting me a Drill Doctor. Do they really work like they say? Do they last or are they something that wears out in a year?
Slowpoke
10-14-2007 23:02:46
 Re: Drill Doctor in reply to Gary From Muleshoe, 10-11-2007 14:05:35
I have the model 750. I have not done anything over 1/2" yet, but quite a few times I find a positive rake on my bits and have to play with the the position of the bit in the chuck to get a negative rake. Any ideas why?
williamf
10-14-2007 05:33:37
I got the least expensive model, couldn't read the instructions ahead of time. It does really well on smaller bits but won't take the adapter to do bits bigger than 1/2". Disappointing as 3/4" is the one size I use most. Still have to use the Dremel to sharpen those, free-hand. Don't have a bench grinder, either.
One day, everything.
Wm
CRUSADER
10-13-2007 09:49:45
Howdy Gary, I don't have one yet, but it is on my list of things to buy. A guy I used to work with swears by it and from what I have seen they work real well, just need to get the better quality one.
Jim
Mike in Ohio
10-12-2007 05:31:35
Don't get the cheap off brand ones. The one I have isn't worth the time to plug it in. The real drill doctors seem to be pretty good from what i've heard. Mike
suptscottyb
10-11-2007 18:55:15
Mine's okay but, I think I need a new diamond grinding disc....
chvet73
10-11-2007 18:10:14
Mine goes 3/4 and I think it was well worth the price. Buy the best one. I saw a new add that the latest model is even easier to use. But I really like mine.
wayneh
10-11-2007 17:05:25
Mine is great! It will sharpen up to 3/4 inch bits. I had to drill a lot of holes in some 1/2" steel the other week with a hand drill, and the bits I sharpened on the Dr. were as good as new!
Wayne
J.C.in AZ.
10-11-2007 15:01:00
I have one,It works good,I've used it a lot with no complaints,"But" I find myself before ever using a Drill bit ,stopping and touching up the Drill Point on my Foley-Belsaw 1" Belt Sander. I have got pretty good at it and very seldom have an issue with the sharpening job I do that way. If I should happen to break the bit off,throw it away and get a new one and hone the cutting edges.Works for me.
TimV
10-11-2007 14:48:48
Love mine--takes less than half the time to sharpen a drill on the Drill Doctor than it does to free-hand grind one, and it's much more consistent. Drills with the point totally gone take longer, and it's usually wise to put a rough point on them with a bench grinder to avoid wearing out the wheel on the drill doctor, but for drills from 1/8" to 1/2" (as big as mine goes) that are just dull, it's the cat's pajamas. You don't realize how dull some of your bits are until you sharpen them and drill your first hole!
Dave Sherburne NY
10-11-2007 14:24:12
I've had one for quite a few years It works great
on bits from about 3/16 up to 3/4" but not on the
smaller ones.
ohio
10-11-2007 14:19:18
They are ok quality wise. there are different models in different price ranges.
As far as usefullnes, if you have a bench grinder and a drill point gauge, you can do as good a job (up to the 3/4" that the d.d. covers) in far less time. Everyone should learn how to sharpen drills.
