Tool Talk Discussion Forum
Vixen Spark Plug Cleaner Help Needed
jcwren
10-10-2007 20:20:11
This message is a reply to an archived post by Ed Utah on November 30, 2005 at 08:48:43.
The original subject was "Re: Spark Plug Cleaner Help Needed".
I have a model #12 Vixen cleaner, and it's got an A/B lever on the side. I haven't used this thing in over 12 years, and I don't remember what the A vs B position does.
Any help out there?
Thanks,
--jc
dobber
10-11-2007 10:56:43
 Re: Vixen Spark Plug Cleaner Help Needed in reply to jcwren, 10-10-2007 20:20:11
Yep Air and Blast. As far as cleaning plugs you need to blow them out with air again and some aerosol carb cleaner works well too for getting all the residue out. If you change the blast media regular and use a moisture separator on your air line so the blast media will stay dry it doesn't stick to the plugs as much then. Use only fine dry glass bead media in plug cleaners just like with other dry blast cabinet. Doesn't hurt to put some light lube of some kind on plug threads then either after cleaning as you will blast the finish off threads too. Cleaned hundreds of plugs over the years wearing out 3 plug cleaners for irrigation engine plugs and others and if you clean them right no problems. Dry air and dry clean blast media important!!
joe fabregas
10-11-2007 06:01:26
As a side note - those things work great but you can never really get all the sand out of the plugs. Can't recommend using them on any engines you value. Good luck. Regards, joe in ny
Bob
10-10-2007 21:08:49
I have another brand of spark plug cleaner with a 2-position lever. One postion is for sandblasting the plug, the other way cuts off the sand, and blasts the plug with air only, in an attempt to clean most of the sand out of the depths of the spark plug, before you reinstall it, and the sand falls out into the engine.
Likely, that's what the lever on your's does, as well. Now to figure out which way is which!
JoeK(WI)
10-10-2007 21:57:11
 Re: Vixen Spark Plug Cleaner Help Needed in reply to Bob, 10-10-2007 21:08:49
A-Air
B-Blast
If I recall correctly :)
