I have the Honeywell VisionPro TH8320U. (Aka a member of the "TH8000 series")It offers a fan mode of "On", "auto", or "circ". In "circ" mode, the fan (only) is run randomly about 30% of the time the system would otherwise be off. I use this feature to get de-stratification and improved air filtering. This mode works really well with a heat pump that has an ECM type blower -- in "fan only" mode the blower runs at 1/2 speed and uses 1/4 of the electricity of full-on mode. Since the ductwork is sized to be reasonably quiet for the full speed of the blower, the fan-only mode is almost dead silent. The TH8000 also offers outdoor temperature sensing and display, and the ability to lock out the "aux heating" unless the outdoor temp is below a threshold set by the user. The RTH8500 looks like it is based on the same chassis, BUT the internal programming appears to have been "consumerized" and emasculated for the "big box store" market. A study of the owners manual shows no fan mode other than "ON" and "Auto". So it won't do what you want. The other poster probably had it right -- the naive consumer thinks "the furnace is running" when it is just the fan. So Honeywell dumbs down the unit for sales to "Handy Andy". You can buy a real "VisionPro" from several different internet vendors, assuming you can handle the product support and low voltage control issues yourself. I really like my unit, but installation is definitely not for the faint of heart -- it takes 10 wires to hook up all the features (Power, return, 3 heat, 2 cool, fan only, outdoor temp sense, fault display).
