Tool Talk Discussion Forum
Thermostat for outdoor boiler
Rayy
10-09-2007 14:55:57
I am trying to hook a seperate thermostat up to my house furnace to turn on just the fan. I am installing a heat exchanger in my duct work from my outdoor boiler and want the fan to turn on with the new thermostat and not turn nothing on the gas furnace unless the temp on my boiler is low and the house furnace will do its thing. It is a Tempstar 92.1 efficient furnace. Does anybody know what terminals to connect. I know the thermostat I have to turn on my furnace now has a fan only switch, but I dont want to introduce power to any other componet, or for that matter back feed current to the second thermostat. Any Ideas?
Butch(OH)
10-09-2007 17:31:36
 Re: Thermostat for outdoor boiler in reply to Rayy, 10-09-2007 14:55:57
Thermostat instructions with OWBs stink dont they? I am no HVAC tech but I did hook up my own thermostats for a similar system and it works perfectly. My original thermostat also had a "fan on" switch. ON mine, and I am told most of the time, the fan on circuit will be wired to the highest fan speed (if you have a multi spped fan) Now memory gets foggy for the terminal letters so check this out before your wire but I think it is R to G to get high fan. All I did was break into the "fan on" circuit in my original thermostat and wired in another thermostat in series, took a foot of wire since they are side by side. To operate the system You set the OWB 'stat to the temp you want and switch the original 'stat to fan on. The fan only runs when the OWB'stat calls for heat. The original 'stat is set a few degrees under so the original furnace acts as a back up. The only fault to this is if you lose boiler temps the fan runs all the time since the OWB stat is calling for heat. The could be easily overcome with a simple auquastat installed in the boiler lines that cuts out the fan controll power at X degrees water temp.
