Tool Talk Discussion Forum
What are these items worth? Cleaning out dads garage
John Williams
10-07-2007 15:01:50
Daytona Metal cutting Bandsaw. Model # WB-600 Serial # 1285
Forney Stick Welder Modle C-5 Serial # 237475
8 HP Kohler Lo-Blo "The Air Broom" Cast Iron Line.
suptscottyb
10-07-2007 19:49:41
 Re: What are these items worth? Cleaning out dads garage in reply to John Williams, 10-07-2007 15:01:50
If you don't get an answer here you can try looking for a similar item on ebay to get an idea of what they are worth, if they have no sentimental value....
rustyj
10-07-2007 16:51:17
Try an advertisement in a newspaper classified section. Or, look up a mechanic, or somebody in your area who might know something about machene tools. A forney stick welder would be fine for the average guy who needs an occasional weld job. Its not recent state of the art, but they were ok in their time. No reason to pitch it out. And, a metal cutting band-saw is useful for the home handy man, or mechanic. there have been times when i wished i had one, when i had to make a long cut in some sheet metal, or when i had to cut thru some heavy round or square stock. Don't know what the air broom might be. by: Rusty J.
vitzarus
10-07-2007 15:27:46
Without getting into the reasons which could be sad I'd like to advise you that model #s are fine but more information puts the meat in the pie. for instance it's a stick welder but by evidence or label it indicates its wattage and weight.Its amperage or what voltage it is set to be powered by.It may be a grand machine predecessor to a Miller Thunderbolt with the finest copper windings but one doesn't know what stage unit this is.It could be crap.I suppose that is what a search online is for but it doesn't always provide what you can. Also that bandsaw.There were Daytons and there were daytonas and ther were carolinas but we need know the capacity or something on the label more than what was presented.
