Tool Talk Discussion Forum
SOS re chicago brushes
suptscottyb
10-07-2007 11:35:52
Hi, need help locating source for brushes and caps for a Chicago Electric cut off saw. I know, I shoulda bought something better, but it is an occasional use tool that has lasted a few years. Hate to throw it away. Help is appreciated. Couldn't find anything on the net... Scottyb
vitzarus
10-07-2007 14:46:23
 Re: SOS re chicago brushes in reply to suptscottyb, 10-07-2007 11:35:52
When you got the saw they probably had a set of repl brushes. The type of hdwe store is one with those slide out boxes. You can possibly match a pair there otherwise go to or write HF andgive them the info of the motor and size of brush.
suptscottyb
10-07-2007 15:17:51
 Re: SOS re chicago brushes in reply to vitzarus, 10-07-2007 14:46:23
Thank you for stating the obvious. I went thru my pile of owners manuals and found the set of brushes you mentioned I should have. Installed them and the saw works with a makeshift hold down cap. Now, to find the brush cap somewhere. Thanks a bunch, Scottyb
vitzarus
10-07-2007 15:44:40
 Re: SOS re chicago brushes in reply to suptscottyb, 10-07-2007 15:17:51
Yeh you need find the right cap but many of thems and those have failed for other reasons.I had a deal in my mind earlier wher you wind in a piece of wax (already shaved to aprox od)and remove it and use for a gage to your closest die which could be some dang plastic close enough to bakelite.I cannot offer suggestions to a point for some element which occurs to you only.Remember as soon as you do it another tool will appear trashed which has that excact part.
Gerald J.
10-07-2007 13:22:38
Good hardware store or motor rewinding shop will have some brushes.
Gerald J.
suptscottyb
10-07-2007 13:46:56
 Re: SOS re chicago brushes in reply to Gerald J., 10-07-2007 13:22:38
Okay, thanks I'll try that for the brushes. But what about the little plastic cap that screws in to hold the brush - it broke coming out.
Gerald J.
10-07-2007 16:22:11
 Re: SOS re chicago brushes in reply to suptscottyb, 10-07-2007 13:46:56
HF or the same places you found brushes.
Gerald J.
Wisconsin Cowman
10-07-2007 12:34:57
Time your done finding brushes would be better off just buying a new one.
suptscottyb
10-07-2007 12:50:17
 Re: SOS re chicago brushes in reply to Wisconsin Cowman, 10-07-2007 12:34:57
Yeah, I just looked it up. Paid 60 dollars for it new. But sure would not buy another one. Guess I have to buy something better. So, does anyone have a 14 inch electric cut off saw that has given exception service?
Ry
10-07-2007 15:06:53
 Re: SOS re chicago brushes in reply to suptscottyb, 10-07-2007 12:50:17
I bought a Dewalt cutoff saw and the armature fried just out of warranty. I replaced the armature and now it works better than ever. It used to pop a breaker quite often even since it was new -the store I bought it from said my shop wiring was to blame. With the new armature no more breaker trouble. I have had bad luck with other Dewalt tool as well. No Trouble so far with Makita. All my Makitas seem to run forever.
suptscottyb
10-07-2007 18:12:54
 Re: SOS re chicago brushes in reply to Ry, 10-07-2007 15:06:53
Yes, I believe with a little luck - ya get what ya pay for...
Thanks for all the input here, Scottyb
