Tool Talk Discussion Forum
no fire
Bennie Hacker
10-07-2007 03:20:34
I pulled the center wire off my dist on my To 20 Massey an no spark at all.I have a multimeter. What would be the next thing to check?
Thx in advance
Slowpoke
10-13-2007 22:07:39
 Re: no fire in reply to Bennie Hacker, 10-07-2007 03:20:34
Make sure the coil tower is clean and bright inside. It could be rusty or corroded. Use sandpaper wrapped around a phillips screwdriver or similar round shaft. Steel wool also works.
markiz41
10-07-2007 10:40:19
What Maark said, plus you may want to check the coil with your multimeter.
Maark
10-07-2007 07:03:42
Run a fine piece of sand paper through the points along with a clean piece of paper afterwards to clean the points. If that doesn't help, replace the condensor.
