Tool Talk Discussion Forum
Jonsered too low bar oil flow rate
Charlie
10-06-2007 18:22:30
I have a Jonsered 2054. Ever since I got it several years ago, there has never been enough oil flowing to the bar, even though I have the adjustment screw turned all the way. I'm even using 10 weight bar oil, even in warm weather. (It doesn't turn very far, about a quarter turn.) Is there any other adjustment? For example, it looks like there is an allen screw next to the adjustment screw. Does this control anything?
Bar heats up, and only a little oil shows on the log when I aim the tip of the bar at it.
Thanks for any help. I'd love to get to the bottom of this.
Charlie
JT
10-09-2007 15:06:41
 Re: Jonsered too low bar oil flow rate in reply to Charlie, 10-06-2007 18:22:30
What do you call not enough oil, all the saws built in the last 10 years use a minimal amount of oil, you know polution, oil contamination, etc, but anyway, you say the blade gets hot, is the bar smoking? The bar will show it being blue where the chain runs if the paint comes off because the bar rails are hardened to be able to use less oil. Another thing that will cause a lack of oil is using the wrong weight bar oil.
Charlie
10-09-2007 15:36:50
 Re: Jonsered too low bar oil flow rate in reply to JT, 10-09-2007 15:06:41
Thanks for your comments. The bar is not smoking, but it's quite hot. I usually check oiling by aiming blade at stump and gunning the engine. My other saws always show oil, but this one does not. I also see a little blue where the bar got very hot. I took the whole oil system apart and found no problems or clogs. I use 30W bar and chain oil in the warm weather. Could this be OK, or should I keep looking for a problem?
jokers
10-07-2007 08:55:28
No offense intended Charlie but I`ve found that probably 9 times out of 10 when someone says they aren`t getting enough bar oil it usually means they are running dull chain, any dulling of the working corner at all constitutes dull. You will also want to check the oil hole in the bar and the bar groove which might be full of compacted saw dust which will absorb a surprising amount of oil. The fine dust often found in the groove is also a sign of using dull chain.
Arkandan
10-07-2007 04:10:49
Here's a link to a Jonsered Workshop Manual. It's in PDF form. It's 126 pages long. You'll need to go to pages 67 & 68 for info on your saw. Hope it does the trick for you.
TyTX
10-06-2007 20:34:43
Don't know how Jonsered is set up but that allen screw might just be the bar oil adjust.
