Tool Talk Discussion Forum
New Holland 256 bearing installation
doug in va
10-05-2007 18:28:00
How do you bolt up the tooth bar of a New Holland 256 hay rake after installing a new bearing? Getting the bearing in the bar is simple. The problem is that the bolt angle prevents the bolt from lining up with the hole. I know there is a trick to it. Thanks Doug
jeff outwest
10-05-2007 21:16:49
 Re: New Holland 256 bearing installation in reply to doug in va, 10-05-2007 18:28:00
Take all but one of the four bolts out of the star shaped plate, on the end that you are working on. Attach a come along to the bar on the opposite end and use a block and Handi-man jack, to bow the bar. Worked for me yesterday on a 260 rake. Uncle, who is older and wiser says take all the bolts out of the star shaped plate and you get enough flex to make in work. He worked at New Holland dealer for 25 years I am sure he more right on the money than I am.
doug in va
10-06-2007 18:23:44
 Re: New Holland 256 bearing installation in reply to jeff outwest, 10-05-2007 21:16:49
Thanks guys, especially Uncle. I loosened all five bearings and that allowed enough play to bolt it up easily.
Mike (OK)
10-05-2007 19:17:43
You need to loosen the bar next to the one you are working on and the right side spider. An extra pair of hands don't hurt either!
Alan in Ok
10-05-2007 18:41:22
both ends have to in at the same time
paul
10-05-2007 20:48:15
 Re: New Holland 256 bearing installation in reply to Alan in Ok, 10-05-2007 18:41:22
Don't think that helps either. It will wedge because of the the angle.
One way is the entire plate on one end needs to have all the bars off of it, install all bearings at the same time.
My 55 rake had a rubber insert, square hole in the plate. It was possible to shove the rubber insert in after getting the bearing into the square hole. This was very tedious, but worked.
Loosening or prying has varrying effects.....
--->Paul
