Electrical Plug for Trailer? Help!
Robin
06-24-2001 21:06:33
Someone borrowed my trailer and pulled the wires off of the electrical plug. I have tried to reconnect the 7 wire (RV-Flat Prong)plug but the wiring scheme on the truck outlet doesn't make sense with what the trailer plug shows. How do I figure out which wire goes to which plug? I need help. Thanks in advance.
RobertN
07-13-2001 13:55:52
 Re: Electrical Plug for Trailer? Help! in reply to Robin, 06-24-2001 21:06:33
Look at>Link
It>Link gives a good description of proper trailer wiring; there is actually a code for this type wiring.
Also look at:
http://www.rverscorner.com/wiring/general.html
Mark Kw
06-25-2001 08:09:18
If the trailer has electric brakes, there should be no need to jack it up, you should clearly hear the magnets snap in when you hit the brake wire with the power.
If you put the emergency flashers on on the truck, you then have a pulsed power going to the brake light pin on the connector. Make sure you have a good gound to the truck from the trailer (usually can find this connector pin easy by looking behind the one on the truck to see the jumper wire to the frame or connector mounting bracket). Now, take one of the wires from the trailer cord and touch it to the brake pin on the truck side. Whatever this wire feeds will be flashing (if it's the brake wire, you should hear the magnets snap in and out on the drums). Tag each wire on the trailer cord when you know what it is. Then turn on one thing at a time on the truck and touch the corresponding wire to the pins till you find the one that has the power on it. Make a drawing as the other guy said and put on copy in the truck and one in the trailer so you have it for future use if needed. Doing it this way eliminates the need for a test light/volt meter and second power source if you don't have them handy.
DumOLeBob
06-26-2001 09:28:16
 Re: Re: Electrical Plug for Trailer? Help! in reply to Mark Kw, 06-25-2001 08:09:18
Honestly, Mark Kw & Junkman (for guys who don't like Chineese tools)come up with more great ways of doing things! You should write one of them "hints" books. Anyway, I need a B-day present for my wife - what da ya suggest?
Paul
06-29-2001 11:32:21
 Re: Re: Re: Electrical Plug for Trailer? Help! in reply to DumOLeBob, 06-26-2001 09:28:16
I got my wife a new sweeper once for Valentine's Day and had six more weeks of cold weather.
Mark Kw
06-26-2001 09:56:03
Chinese tools have their place and I do own a lot of them...especially when theft or other loss is a problem and performance is not critical. If someone swipes a $10 set of wrenches, who cares? If they try to swipe my $1000 set of snappies, I'll be looking to test out the patterning of my 12 gauge on them. he he
Without knowing your wife Bob, you usually can't go wrong with flowers, a nice dinner out (not fast food) and jewelry. On the other hand you have those "one of the guys" women that would be overly happy with a new set of sockets or a cordless tool too. Got a female friend of mine, had her a custom gold necklace made for her Christmas of '97 that I don't think she wore twice since that day. Got her a 14.4 cordless Milwaukee drill for her B-day last June and she about has it wore out. All in thier tastes. he he Good luck (just stay away from things like irons and sweepers, tends to PO all of them real quick!)
Junkman
06-24-2001 21:32:28
Robin, Take a test light to the plug on the truck to find out how the truck plug is wired. Make yourself a little sketch of it. Now take a 12 volt power source (extra car battery, jumper wire form another car's battery, or battery charger) and connect it to each wire on the trailer. Note what wire does what, running lights, turn signals (these will not blink at this point, but only one side will light up at a time). You will need at least one side of trailer off the ground to find the electric brake wire. To find brake wire, have someone spin the tire while you touch each extra wire to power. When you find the brake wire, the tire will stop. You should be able to trace the ground wire to the frame somewhere close to the hitch, and you probably have a wire for charging the batteries if this is an RV trailer. You are going to have to get someone else to help with that one. 8^) I hope this helps and feel free to contact me if I can be of further assistance.
John
